Dead fingers
Quickly
PostPosted: 17:38 - 04 Apr 2010    Post subject: Dead fingers Reply with quote
My middle finger always goes all white and numb when I'm on a long ride, I think I must put more pressure on it than on the others. Tying gaffer tape around the bottom before a ride - is that going to kill it or stop it going numb?
Dagon
PostPosted: 19:09 - 04 Apr 2010    Post subject: Reply with quote
Any vibration through the bars? That can cause it.
Clanger
Stirrer
PostPosted: 21:33 - 04 Apr 2010    Post subject: Reply with quote
It's bad circulation. I get it all the time, and when out on the bike, I get it worse and in more fingers. It's something I have to live with, and manage. Heated grips may help, as with bar muffs.
ulster exile
PostPosted: 21:49 - 04 Apr 2010    Post subject: Reply with quote
Sounds like vibration white finger
I don't have that, but I do have carpal tunnel syndrome so my hands occasionally go numb. That's fun.
Crawford
PostPosted: 22:42 - 04 Apr 2010    Post subject: Reply with quote
Could also simply be that your gloves are too small, the tip of your fingers shouldn't touch the end of the glove fingers.
69.9mph
PostPosted: 11:43 - 05 Apr 2010    Post subject: Reply with quote
Some things you can try:
Different gloves.
Changing the grips to a smaller/larger diameter or harder/softer compound.
Heavier or lighter bar end weights if you're getting vibration.
Changing the handlebars will alter the weight distribution across your hand.
That should keep you occupied for a while Wink
PostPosted: 12:16 - 05 Apr 2010    Post subject: Reply with quote
Different gloves.
Agreed. Larger diameter grips, heavier bar-ends. One thing you mustn't do is nothing at all. It won't take many miles of riding for it to cause permanent damage.
PostPosted: 12:21 - 05 Apr 2010    Post subject: Reply with quote
By the way, there's more than one way of getting 'dead fingers':
https://www.gixxer.com/forums/showthread.php?t=242261
teech
PostPosted: 12:33 - 05 Apr 2010    Post subject: Reply with quote
Hi Clanger,
Also, if you have bad circulation in general then try a herbal thing called Ginko Biloba. It's scientifically proven to help bad circulation as it promotes freer flow of blood to the extremeties like hands, feet and brain. I use it to help me learn lines quicker. it's good stuff.
In everyday life good people do good things, bad people do bad things. It takes religion to make a good person do bad things.
Quickly
PostPosted: 12:43 - 05 Apr 2010    Post subject: Reply with quote
Thanks for all the tips guys, will give some of these a try. And yes, it is vibration white finger. You're all stars. Middle Finger Wink
Clanger
Stirrer
PostPosted: 18:39 - 06 Apr 2010    Post subject: Reply with quote
teech wrote:
Hi Clanger,
I have a problem with tablets...it's all hit and miss as to whether they work, due to a malfunctioning liver. If there was a magic hand rub, it would have a better chance of working...(for me personally) Smile
The last post was made 16 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 72.81 Kb
