US plugs
GodzGift
PostPosted: 16:44 - 05 Apr 2010    Post subject: US plugs Reply with quote
Hi Chaps
Anyone been to the states before and used one of those UK to US plug adapters?
They are pretty cheap on ebay, a few quid but is that all thats needed? I assumed in the US they use a different voltage to the plugs in the UK?
Will I need anything else besides the bog standard UK to US plug adapter?
Ta
Arrow Karma
Bike Level: Amateur | CBT Passed
SlimRick
PostPosted: 18:10 - 05 Apr 2010    Post subject: Reply with quote
US is 110v, UK is 240v. It should say on whatever your plugging in whether it car run on either. If it doesn't say, assume it won't work on 110v.
Phoenix
Twisted Firestarter
PostPosted: 19:26 - 05 Apr 2010    Post subject: Reply with quote
Usually anything that has a large voltage transformer built into the plug or in the plug cable will be able to run on UK and US voltage, it'll have a label on saying something like Input:230-240v/110v, anything that doesn't have a transformer built in will have the label on the appliance itself and will mostly likely only run on 230-240v. So basically anything you're likely to be able to fit in a suitcase will work, except stuff like hair dryers and other girly appliances.
mistergixer
PostPosted: 21:06 - 05 Apr 2010    Post subject: Reply with quote
Don't the Yankee-doodles run on 60Hz instead of our 50Hz?
Can cause some problems - mostly overheating due to current draw. Check to see if the PSU shows frequency as well as voltage.
Space Monkey #7
The last post was made 16 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 40.25 Kb
