| Quickly |
 Quickly Crazy Courier
| Ariel Badger |
 Ariel Badger Super Spammer
| Ariel Badger |
| Quickly |
 Posted: 22:08 - 05 Apr 2010 Post subject: |
Unfortunately not. I left home at 6.30 but had to turn back at Carlisle. The weather was atrocious and was forecast to be the same all across the north (including York) all day. The sidewinds were blowing me all across the carriageway - the kind where you have to slow down because just leaning into it isn't enough - and I had to go over the North Yorks Moors to get there. Decided it was better not to risk it.
To be honest I wasn't too disappointed - I wanted to do it today but if the weather was going to be that bad there I'd not be able to top much over 70 mph. Wouldn't be competitive at all over the course of the season, and it's an expensive day out to do basically a RWYB.
Next chance is May 8th at Kirkbride near Carlisle, less than an hour away (there is a meeting on the 18th, but I'm at Oliver's Mount that day). When I first signed up I'd planned Kirkbride to be my first anyway, and it means a few friends can come down and watch too. I've kept your advice written down so will be revisiting it then.
Did you have a run anywhere today? ____________________ ... |
| G |
 G The Voice of Reason
| Ariel Badger |
 Posted: 23:30 - 05 Apr 2010 Post subject: |
Sprinting is not drag G, it has similarities but it is not the same. For a start we use a different starting system that is not down to reaction time and we race against the clock rather than the next lane ( a lot of sprints are single lane so we go one at a time). Then there are twisties, we sprint for 1/4 mile but with corners
Yesterday I did a hillclimb ( this is in reality a very long sprint with a lot of corners over a longer distance and up a bloody big hill) It was 7/8 of a mile and it was not my best day on the track.
Run one (practice) I was far too enthusiastic and went off on turn 3 and did some off roading but got it back together only to take another bend without enough lean and had to hit the bars to pull me back from the green stuff causing a steering wobble at about 80, then my engine cut due to a broken cable tie shorting my mag resulting in a red flag.
Run two (practice) great run, went through the last bend and over the brow of a hill full throttle towards the finish line only to be confronted by the actual last bend, a 120 degree right hander I had no chance of getting through so I just aimed at the tyre wall and scrubbed speed until the impact (very low speed as hitting a dirt bank first slowed me so no damage). red flag.
Run three (for real) got to the top but not impressed with my time.
Run four (for real) Went for it and dumped the clutch on the line with 5000 RPM on the clock, not much happened except my clutch slipped a then bit but slipped as I powered up the hill so I aborted and returned to the paddock.
Day over.
The motor is running like heaven despite two silly mechanical probs and one rider error ____________________ Bikers make great organ donors, get 115 on your licence today. |
| G |
 Posted: 23:47 - 05 Apr 2010 Post subject: |
I believe a lot of drag racing is often done on times rather than the winner of a specific pairing (the competitive stuff I've been entered into has been like this).
From the previous thread I had a look here:
https://www.sprinting.org.uk/about.html
The site isn't too useful, but only details straight line stuff.
I had previously thought of sprinting as a hill climb but without having to have a hill - possibly even doing a single lap of a track or similar. However from the above site I presumed it was just straight lines.
The talk of 400hp Busas was the clarification needed that it was probably just straight lines (you can't have that significant corners to make a 400hp still sensibly competitive against stock superbikes that can get down plenty of power and turn corners.)
Got links to any videos of sprints with corners? Youtube doesn't show up much with obvious searches.
(This is 1/4 miles with corners, I'm well aware of the way road hill climbs work ). |
| NSR Mick |
 NSR Mick World Chat Champion
| G |
| NSR Mick |
| Ariel Badger |
 Posted: 22:03 - 02 May 2010 Post subject: |
I got third in my class at Houghton today despite having the gearing set up wrong. Bring on round 2 in September  ____________________ Bikers make great organ donors, get 115 on your licence today. |
The last post was made 16 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
