de-resticting honda ns125rk
nick10121974
PostPosted: 07:13 - 07 Apr 2010    Post subject: de-resticting honda ns125rk Reply with quote
hi dose anyone now how you de-restricte the honda ns125rk i know on the nsr its the power valve on the side of bore but the ns dont have this it just has a blank there. ive got three of these bikes and one of them has been de-resticted and the only thing difrent is that there is no blank valve in the side of the bore some one has boged it up
PostPosted: 09:27 - 07 Apr 2010    Post subject: Reply with quote
The restriction is in the exhaust. The ATAC chamber (on the side of the barrel) on full power bikes opens and closes depending on rpm. At high rpm it would be closed and open at low rpm.
nick10121974
PostPosted: 21:01 - 23 Apr 2010    Post subject: ns125 Reply with quote
hi can some one help out here ive done a rebuild on the engine and it sounds nice but it keeps getting hot it will go past half way if you let it ive tryed all sorts changeing rad fule mix thermastat
PostPosted: 21:30 - 23 Apr 2010    Post subject: Reply with quote
Have you got the right mix of water and anti freeze? Does the water pump work? Are the radiator fins in reasonable condition? Is it using coolant? Has the ignition timing slipped?
The last post was made 16 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 40.22 Kb
