Power to weight ratio units?
Visitor Q
$25 whore
PostPosted: 21:29 - 07 Jul 2004    Post subject: Power to weight ratio units? Reply with quote
Hi guys, was just wondering what the general forumla and unit for the power to weight ratio of a bike/ car would be so i can feel smug when telling chavs why my 'little' 350 will demolish them from the lights in their little novas.
I would imagine it would be weight / bhp ergo
R1 = 1 because it is 180kg / 180 bhp
My bike would be 145kg / 32 = 4.531
Etc
Altho im not sure which way it would be done, what unit, etc etc. Any help?
McJamweasel
BCF Junkie
PostPosted: 21:32 - 07 Jul 2004    Post subject: Reply with quote
Nope.
Power/Weight. So more like 32/145 = 0.22 bhp/kg.
Visitor Q
$25 whore
PostPosted: 21:40 - 07 Jul 2004    Post subject: Reply with quote
McJamweasel wrote:
Nope.
Coolio.
I just recalled the R1 had 1.
But anyone got some general bhp/kg indexes of like novas/pug 306 (just general chavish ped boi cars usually festooned in max power add ons and spotty 14 yr old girls)
Dr Nick
PostPosted: 21:51 - 07 Jul 2004    Post subject: Reply with quote
bonny_ricardo wrote:
McJamweasel wrote:
Nope.
Coolio.
All the new litre bikes got about 145bhp at the rear wheel in the performance bikes test. Confused
is that it
McJamweasel
BCF Junkie
PostPosted: 21:55 - 07 Jul 2004    Post subject: Reply with quote
Very true Nick. According to the factory claims, the R1 do indeed have 1 bhp/kg - however so does the ZX10. When you take into account the bollocks that the factories claim, however, both fall short.
Visitor Q
$25 whore
PostPosted: 22:00 - 07 Jul 2004    Post subject: Reply with quote
Yes but no doubt you would work it from the crank cos bearing in mind the wet weight would add on about 20 kg usually (give or take) so just take the easiest to measure. Rear wheel bhp will have lots to do with chain, sprocket, tyre etc... Crank at least will be consistent.
I dunno. its all too confusing Neutral
McJamweasel
BCF Junkie
PostPosted: 22:01 - 07 Jul 2004    Post subject: Reply with quote
Consistent? Maybe, but of very little value in the real world.
Visitor Q
$25 whore
PostPosted: 22:03 - 07 Jul 2004    Post subject: Reply with quote
true BUT bear in mind an R1 with a 150kg lisa riley squatting on it is gonna have a worse power to weight then an R6.
Not to mention the aerodynamics.
However we arent taking that into account are we.
Simple ball park figures are the best way to do things.
PostPosted: 22:13 - 07 Jul 2004    Post subject: Reply with quote
Its a ratio... technically it has no units! Laughing
I mean fancy saying bhp per Kg... thats an imperial versus a metric unit!
Ratios don't have units, they are just for comparison purposes. EG, Yamaha R1 claimed weight 176kg, claimed power 176bhp. Power to weight ratio of 1.
Triumph Daytona 955i. Claimed power 147bhp, claimed weight 189kg. Power to weight ratio of 0.78.
R1 has greater power to weight ratio than Daytona.
Thats the only use that a Ratio has. Ratios are never expressed with units. Smile
I'm sorry if that rambled a bit, but I have just done a 12 hour shift with no breaks and no food. Confused
dibbster
PostPosted: 00:14 - 08 Jul 2004    Post subject: Reply with quote
Ratios aren't expressed with units but you need to mention units as if you converted R1 weight quoted to pounds all of a sudden it has a lower power to weight ratio than the triumph. (176bhp and 387lbs gives power to weight ratio of 0.45)
So the units of power and weight must be mentioned, incidently the figure quoted by DVLA for the two year restriction period is a power to weight ratio not exceeding 0.16kW/kg.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
Mr C
PostPosted: 01:42 - 08 Jul 2004    Post subject: Reply with quote
of course you have to specify units
you can only have a real ratio if you are comparing apples and apples - if not then you have to specify units
the R1 has a 1:1 ratio (pffffft yeah right Rolling Eyes )
anyhow
let's let them have that for now and say that a mythical R1 has 180bhp and weighs 180kg
so it has a power to weight ratio of 1 (no units)
no it doesn't
it has a power to weight ratio of 1 bhp per kg
or 133kW per 6349 ounces
or 735Nm/s per 3.54cwt
and so on
none of these are unity apart from the arbitrary ratio chosen
so no, power to weight ration can't be expresed without units at all Razz
187.3bhp = 201mph
Frost
PostPosted: 01:52 - 08 Jul 2004    Post subject: Reply with quote
power to weight also must be taken with a pinch of salt, especially when compairing bikes to cars. take a 180kg bike, and calculate its power to weight ration, then plonk a 90kg fatass on it and all your statistics are utterly ballsed up. slap the same fatass in a 1 tonn car and his weight will make less of an impact on the figures.
power to weight cant allways be used to determine which vehical is faster as drag is not taken into account.
typically bikes wipe the floor with everything power to weight wise, untill you put a rider ont he bike at which point they become the more powerful by a slimmer margin. Bikes still own 99% of cars though Wink
Adam_P
PostPosted: 01:53 - 08 Jul 2004    Post subject: Reply with quote
The best way to impress the chavs would be to work it out in bhp per ton (tonne?) That way, it will work along the same lines as their car power to weight ratios, and you'll walk all over them!
For instance, the Caterham R500 is quoted as having 500bhp per tonne, that's because the car weighs less than a tonne, but the power output ratio (this is where Marjey's ratio bit comes in to it!) would work out to this figure if it did.
A bik weighs the better part of sod all, so whatever it is, it'll be a damn sight better than a max powered nova, especially with all the filler and extra weight they carry with speakers, amps, bodykits and obligatory tracksuit bottom wearing/McDonalds eating girlfriend.
However, I haven't the faintest idea how to do the maths to get to the figures. But, I'm sure someone will. It sounds like Mr C does already! Wink
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
Wave2k
G's Stalker
PostPosted: 02:06 - 08 Jul 2004    Post subject: Reply with quote
MY head hurts Confused
Ducati 1299 Panigale
2009 Corvette C6 z51
mchaggis
PostPosted: 02:18 - 08 Jul 2004    Post subject: Reply with quote
In which case, your mythical R1 has a power to weight ratio of 1000 bhp per ton. Beats the pants of pretty much any car. There are special cases, with F1 cars, 940ish bhp in a 600 kg car, gives you about getting on for 1600 bhp per tonne.
The Clio 172, 172hp per 1055kg gives you a poxy 163 bhp per tonne. Laughing A CG125 probably has getting on for 100 bhp per tonne... Chav's eh.. stick that up them.
Frost
PostPosted: 02:31 - 08 Jul 2004    Post subject: Reply with quote
As i said though, 14 bhp CG weighing 120kg = 116bhp/Ton
Add a rider and : 14 bhp CG weighing 180kg = 77bhp/Ton
Chavmobile 172 172bhp, 1055kg = 163bhp/Ton
Chavmobile 172 + Chav 172bhp, 1115kg = 154bhp/Ton
The addition of a person weighing the same amount to both vehicals caused a 5.5% drop int he power to weight ratio of the car and a 33.3% drop in the power to weight ratio of the bike.
What have we learned?
If you wanna race Chavs on a CG125, go on a diet! Wink
Robby
Dirty Old Man
PostPosted: 05:44 - 08 Jul 2004    Post subject: Reply with quote
Working in bhp/kilo because its more relative to bikes:
Roughly:
1.0 Nova. About 45bhp and 800kg. So it has 0.056 bhp/kilo
1.3 golf. 60bhp and 880kg going by haynes. 0.068 bhp/kilo. I had one of these. They're slow.
2.6 merc. 160bhp and 1200kg. 0.133 bhp/kilo. In car terms thats not bad.
To compare against some small bikes:
NSR125. 24bhp, about 140kg. 0.171 bhp/kilo. Still poor. Pissy little 125s.
GS500. 50bhp, about 170kg. 0.294 bhp/kilo.
CBR600. 95bhp, about 180kg. 0.52 bhp/kilo.
Then above this the weight stays the same or gets less, and the power just shoots up. Big power in the litre class bikes. As much as my car, and that like to spin its wheels and kick hard when you poke it.
PostPosted: 08:23 - 08 Jul 2004    Post subject: Reply with quote
That's about the same as MrC's 180hp r1 Razz.
Think they were claimed to have 11hp... so maybe 10 realistically at the back wheel Smile.
byke95
PostPosted: 08:45 - 08 Jul 2004    Post subject: Reply with quote
This is how I work out power (for sports bikes)...
Under 600cc = Quick
600cc = Fast
750cc = Very Fast
1000cc = Fooookin Fast..... Shocked
Bendy
Mrs Sensible
PostPosted: 08:48 - 08 Jul 2004    Post subject: Reply with quote
bhp per £1 is sometimes quite interesting too.
Lets just say, my Micra kicked my CBR's ass on that front.
Hey, I had to let the Joy Machine win on something, it weighed three and half times what my bike does and put out less than half the power. Bless it.
Mr C
PostPosted: 12:11 - 08 Jul 2004    Post subject: Reply with quote
and that one is an exponential scale
more and more money for less and less performance improvement Shocked
187.3bhp = 201mph
Fat Controller
PostPosted: 14:12 - 08 Jul 2004    Post subject: Reply with quote
Take a secondhand bike into the equation and it gets even sillier! This is quite a good line but no-one has mentioned adding torque into the equation yet.
bhp at crank/dry weight multiplied by torque
Oh and while we are at it why not add in faired or non faired i.e wind resistance.
Still with me riding it'd go nowhere!!
Stressed as usual! Cheap Sports Bike Insurance https://www.accessquotes.co.uk/BikeQuote.aspx?referer=007
The last post was made 21 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.47 - MySQL Queries: 15 - Page Size: 121.88 Kb
