| gwernybwch |
 gwernybwch Nova Slayer
| Pete. |
 Pete. Super Spammer
 Posted: 18:52 - 07 Apr 2010 Post subject: |
Personally I think the whole 'addicted' thing is a load of tripe. The fact that you are needing to use starting fluid suggests the engine has a problem that prevents it starting normally. By using the fluid you're not addressing the problem and eventually it gets worse until it won't start at all.
To answer your question, no, there's no reason not to use it, but take note of the above. ____________________ a.k.a 'Geri'
| N cee thirty |
 N cee thirty Banned
| Kickstart |
 Kickstart The Oracle
 Posted: 19:07 - 07 Apr 2010 Post subject: |
I would agree with Pete. Don't see why anything would get addicted to it. Use it constantly and yes it might wash the oil from the bores, same as using the choke. With a diesel I would be more concerned that it will probably ignite a long time before TDC.
With a 2 stroke the only extra concern would be it igniting under the piston. While possible I would expect that to need a fair bit of heat (and possibly a spark), which would likely mean the engine running so it probably wouldn't need it.
All th ebest
| Pete. |
 Pete. Super Spammer
| finpos |
 finpos World Chat Champion
| crackpotterpi... |
 crackpotterpi... Renault 5 Driver
| Pete. |
 Pete. Super Spammer
 Posted: 19:50 - 07 Apr 2010 Post subject: |
I had the dubious pleasure of having to demolish part of the building on top of Churchill's old wartime bunker in Westminster. On the roof was a plant room with a huge diesel engine in it, a backup power generator. Whilst rummaging around I round a box with some small canisters labelled 'starter fluid'. One got smashed somehow and sure enough it was ether-based fluid.
I enquired with my dad (who has been a diesel fitter his whole life) and he said yes on the engine would be a receptacle for the canister and you had the charge the engine with the fluid to start it from cold. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 19:53 - 07 Apr 2010 Post subject: |
Incidentally, most penetrating fluids will do the same thing but not as effectively. If you remove the air filter and crank the engine whilst squirting the fluid in the chances are it'll fire. We have a rarely-used machine at work which has a worn governer and sometimes it sticks completely shut. Once the engine fires the vibrations allow the governer to move.
As crackpotterpig said it does make the engine rattle for a few seconds though. ____________________ a.k.a 'Geri'
The last post was made 15 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
