what vfr? UPDATE bought one!
chillyman0
PostPosted: 20:20 - 07 Apr 2010    Post subject: what vfr? UPDATE bought one! Reply with quote
well im looking to change up from my bandit to something that will handle commuting a bit better. I was looking at the vfr's and i am kinda stumped as to what one is the best/does the best/ best value etc etc
i will have around 2k to spend so where is my money best spent?
top nick late 90's 750?
pre vtech 800?
or fork out a couple of hundred more for the 2001+ vtech (probably with fairly high mileage)?
all opinions and advice wanted, cheers
Aaron
mr.kris
PostPosted: 20:23 - 07 Apr 2010    Post subject: Reply with quote
for 2 k the only V tech u can get will be FECKED enless ur Very lucky id go for a VFR800i get the best u can aford
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
TUG
PostPosted: 20:25 - 07 Apr 2010    Post subject: Reply with quote
Get the 750 and revel in its awesomeness, it was the best of the VFR range and is still the best in terms of reliability etc.
Haz ER-5, innit!
chillyman0
PostPosted: 20:30 - 07 Apr 2010    Post subject: Reply with quote
yes hence why i said for a couple of hundred more, i have seen 2002 vtechs with 50-60k miles go for less than £2500
mr.kris
PostPosted: 20:34 - 07 Apr 2010    Post subject: Reply with quote
i may well have a VFR 800 Vtec in a few weeks will be up at about 3250 scrapes on the right hand side nothing mega has hard paniers and will have a brand new rear tyre alarm imobilser rear brake pads and just have had a service if ur intrested let me know only going to have about 25k on the clocks tho
chillyman0
PostPosted: 20:38 - 07 Apr 2010    Post subject: Reply with quote
does sound good but thats a bit out of my price range at the moment, need to see what i can get for my bandit and my clapped out bandit4 thats sitting in my garden
mr.kris
PostPosted: 20:41 - 07 Apr 2010    Post subject: Reply with quote
lol no worrys also got a bandit 1200 for sale LTD edison 2005 alarm imob good tyres only got 7000 miles on the clock nice condision its a 1200 S im looking for about £3000 for that
hmmmnz
PostPosted: 21:05 - 07 Apr 2010    Post subject: Reply with quote
why would anyone buy the vtech honda??
the only reason you'd buy the vfr is to have the reliability of gear driven cams, and of course the lovely v4 noise,
since the vtech is just chain driven, you are essentially just buying a bike that is excessivly complicated without the bulletproof reliability of previous models.
having worked on vfr's and vf's
i'd say through experience, that if you can possibly avoid doing work on a v4... then do it, v4 = angry mechanic Very Happy
the humans are dead
I kick arse for the lord
chillyman0
PostPosted: 21:07 - 07 Apr 2010    Post subject: Reply with quote
so is that saying not to go for the vfr's full stop or just not the vtechs?
cheers
PostPosted: 22:04 - 07 Apr 2010    Post subject: Reply with quote
I've found my late model 750 very easy to work on. You just need to take enough bits off to get at where you need to work on.
People get frustrated because they are trying to work around things like the radiator and airbox. Take them off.
I bet I could pull the carbs off my VFR more quickly than I could on a GPZ500 and I could DEFINATELY re-fit them quicker.
chillyman0
PostPosted: 22:09 - 07 Apr 2010    Post subject: Reply with quote
what are the 750's like then stinkwheel? i have never seen one up close so wouldnt know how similar they are to the 800s in performance/economy etc, would you recomend?
BenR
PostPosted: 22:10 - 07 Apr 2010    Post subject: Reply with quote
VFR800Fi (pre-Vtec) the best of the bunch, certainly the best looking one IMO. Thumbs Up
chillyman0
PostPosted: 22:16 - 07 Apr 2010    Post subject: Reply with quote
so do the 750's poke out more power?
bikez quotes 108bhp with 74Nm torque for the 750 and 98bhp with 75Nm torque for the 800 (99 model)
tvchimp
PostPosted: 22:52 - 07 Apr 2010    Post subject: Reply with quote
yes.
chillyman0
PostPosted: 22:58 - 07 Apr 2010    Post subject: Reply with quote
yeah i read over that again, I did sound quite stupid, i just wondered what they did to 'improve' the engine that lowered the power in the newer models lol
well i think the 750 had taken my fancy more so than the 800's, and they look nicer in my opinion Smile
tvchimp
PostPosted: 23:07 - 07 Apr 2010    Post subject: Reply with quote
https://www.hondabikespecs.com/pics/91-vfr750s.jpg
That's the same as mine, although mine is currently a gun-metal grey with white wheels, I really want to get the exhaust swapped to the left side (it's currently on the right infront of the wheel) so I can show off the sexy single swingarm... Costly to sort out though and means removing the centre stand. Sad
It's a pretty sexy bike. Thumbs Up
PostPosted: 01:33 - 08 Apr 2010    Post subject: Reply with quote
I can't really fault mine.
Yes, the exhaust needs moving to take advantage of the single sided swingarm (as standard, you have to move the exhaust to remove the rear wheel). After doing this, you can remove the wheel with four nuts. I have two wheels, one with a touring tyre for motorways, one with a sports tyre for hooning. Takes about 2 minutes to change with a high level exhaust.
Apparently the plastics are a bit of a pain on the 800s but the plugs are easier to get to due to the side mounted radiators (carbs and tappets are harder though, unless you remove the radiators). The 800 has much better, but fiddlier to work on brakes.
They're not quite as fast as a full-on sports bike but the comfort and ease of riding makes up for it. They'll carry loads of luggage and a pillion and actually handle better when loaded up. They are totally overengineered compared to anything else I've owned and a pleasure to work on (some bits are fiddly, but they come apart and go back together without breaking).
chillyman0
PostPosted: 13:47 - 28 Apr 2010    Post subject: Reply with quote
have sold the bandit and just put a deposit down on this Smile https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190389992458&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D190389992458%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
being delivered for free to my girlfriends in leicester in a few weeks...
new tyres, high level exhaust, alarm and more to come Razz
PostPosted: 15:26 - 28 Apr 2010    Post subject: Reply with quote
Looks very clean. Thumbs Up
The WP shock is a good thing.
hmmmnz
PostPosted: 16:01 - 28 Apr 2010    Post subject: Reply with quote
nice one, good to see you went for the gear driven cams Very Happy
the humans are dead
DrDonnyBrago
PostPosted: 16:11 - 28 Apr 2010    Post subject: Reply with quote
Good stuff, I expect a photo whoring session to commence shortly Thumbs Up .
chillyman0
PostPosted: 22:24 - 28 Apr 2010    Post subject: Reply with quote
dont worry, photos will be up shortly. sold the bandit for only a £50 loss after putting on 6000 miles and some minor crash damage after having her a year! not bad i reckon.
DEN MONKEY
PostPosted: 10:44 - 29 Apr 2010    Post subject: Reply with quote
by the ad it sounds like he's looked after it and it quite honest about it.
Hope it turns out that way.
and yes pics are a must Thumbs Up
meh
The last post was made 16 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 118.46 Kb
