| Haze |
 Haze Derestricted Danger
| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 16:35 - 09 Apr 2010 Post subject: |
Have you checked the float is set to the correct height, and the gasket between the bowl and body is in good condition? ____________________ A Guide To Powerbands |
| Haze |
| Mr Hammers |
 Posted: 17:30 - 09 Apr 2010 Post subject: |
Check your manual to see what height it should be at and measure it, and while you're there make sure the float bowls are leaking.. or rather letting fuel in. That and clean your float valve - the big needle bit that sits on the other end of the float bowls and stops too much fuel entering the carb.
It's most likely to be one of those two, I'd say. ____________________ A Guide To Powerbands |
| yvaiwhy |
 yvaiwhy Borekit Bruiser
 Posted: 23:00 - 09 Apr 2010 Post subject: |
check the throttle cable...it must be stuck or something... ____________________ Don't break the speed limit, Just multiply it by 10 times and you will be fine  |
| Blau Zedong |
 Blau Zedong Banned
| alains |
 alains World Chat Champion
The last post was made 16 years, 127 days ago. Instead of replying here, would creating a new thread be more useful? |
