can the carbs be cleaned on the bike?
steppen22
PostPosted: 17:27 - 10 Apr 2010    Post subject: can the carbs be cleaned on the bike? Reply with quote
Would it work to spray carb cleaner into the carbs directly (air filter out) - ??
Is there any way of cleaning the carbs without having to remove them?
Thanks.
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
nasty
PostPosted: 17:37 - 10 Apr 2010    Post subject: Reply with quote
Put some Redex through your fuel system Thumbs Up
ZX6R F3
WildGoose
White Van Man
PostPosted: 18:02 - 10 Apr 2010    Post subject: Reply with quote
I've not had a lot of success spraying carb cleaner directly through the horns of a carburettor in terms of how much improvement it makes.
I personally think Redex is a waste of time, its well marketed with a cool name but its usefulness is highly over rated.
Best way is to remove the carbs, and remove the jets for proper cleaning, you can then also visually inspect the results.
Some carbs are easier to remove than others, despite how complicated it may look.
Whats the problem with the bike?
Bubbs
PostPosted: 18:15 - 10 Apr 2010    Post subject: Reply with quote
REDEX did f**k all for my carb. I don't quite know the usefulness of it. I assume it's to get rid of the very small amount of build up but it did nothing for mine. Had to clean the jets myself following haynes with instructions that only a mechanic could follow.
PostPosted: 18:41 - 10 Apr 2010    Post subject: Reply with quote
THe 'cleaning' that needs to be done in a carb is the bowl,jets,emulsion tube etc. Spraying carb cleaner into the throat will not affect any of these.
nasty
PostPosted: 20:18 - 10 Apr 2010    Post subject: Reply with quote
Fill your tank and add a Redex "One Shot", take the bike out for a good run.
Others have said they don't really rate it but for £1.99 it's worth a shot.
As has been said though, stripping the carbs and cleaning out the jets etc is probably the best soloution to any fuel/performance issues.
Don't forget to replace the air filter/clean it if after market, that may help a lot.
ZX6R F3
temeluchus
PostPosted: 23:10 - 10 Apr 2010    Post subject: Reply with quote
you MAY be able to get the float bowl off with the carb(s) in situ, depends on the bike. Easy on a Boxer BMW, also possible i guess on some downdraught engines.
Id imagine most sidedraught motors would be tricky to impossible. Most sidedraught fours like bandits etc it couldnt really be done.
The last post was made 16 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 56.58 Kb
