| Bubbs |
 Bubbs World Chat Champion
 Posted: 17:59 - 10 Apr 2010 Post subject: MOT FAIL |
My MOT failed because the brake light doesn't work when the brake is activated. The rear light works on it's own but seems to cut out now and again but with a sharp tap it goes back on.
The lads in the garage are more than happy to fix it at 50quid an hour but I was hoping you knowledgeable bunch know about electrics and what i should check. I thought maybe I should just buy a new bulb but it it's working now and again so I thought it must be a connection issue.
Anyhow any advice would me much appreciated.  ____________________ Life begins at the end of your comfort zone. |
| Kaph |
 Kaph Nitrous Nuisance
| Bubbs |
| Ichy |
 Ichy World Chat Champion
| Ingah |
 Ingah World Chat Champion
| neil. |
 neil. World Chat Champion
 Posted: 20:41 - 10 Apr 2010 Post subject: |
Get some contact cleaner and cotton buds and clean up the contacts on the bulb and in the holder. If it's the YBR, round the back of the bulb holder are spade connectors, pull them out, remembering the order of coloured wires and clean them up as well. You need to remove the side panels, seat, luggage rack and cowling (in that order) to get decent access (it's quick and easy). Give everything a smear of ACF50 for good measure before reassembling. Wire brush/wool over the contacts with contact cleaner if they are really bad. Then change the bulb if that fails as it could just be on its way out. If none of that sorts it, then the problem is in the wiring loom or brake light switch, but that seems unlikely if you just need to tap the light fitting itself.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
The last post was made 16 years, 207 days ago. Instead of replying here, would creating a new thread be more useful? |
