636 front end issue?
tutton
PostPosted: 19:57 - 10 Apr 2010    Post subject: 636 front end issue? Reply with quote
Seems the 636 has a issue which is slightly concerning me,
Everytime you brake quite hard, the front end makes like a loud click, loud enough to hear in my lid with visor down, it does this everytime you brake hard..
Anyone got any ideas what it could be?
I have been getting a bit fun with popping the front up
Possible head bearings?
MaybeGuy
PostPosted: 20:07 - 10 Apr 2010    Post subject: Reply with quote
just tighten them.
ill do it for like a 5er on the 18th
in future, leave about 3000rpm for your landing
tutton
PostPosted: 20:08 - 10 Apr 2010    Post subject: Reply with quote
Alright mate,
If i havnt got em done by then then yeah will do!
Guessing thats what it is,
cant think of anything else that would start randomly making that noise under braking...
Yeah, landing is still a bit hit and miss, trying to glide it down when my body is telling me to chop the throttle is tricky to master Sad
MaybeGuy
PostPosted: 20:14 - 10 Apr 2010    Post subject: Reply with quote
you should be able to feel it through your bars if its head bearings.
or loose floating disks
tutton
PostPosted: 20:30 - 10 Apr 2010    Post subject: Reply with quote
Its like hard to know wheres its coming from as its quiet unless actual riding and braking hard, would be able to feel play in the disc if was loose tho...,
MaybeGuy
PostPosted: 20:45 - 10 Apr 2010    Post subject: Reply with quote
only if the hub was loose. If the disk is loose it can be hard to spot.
tutton
PostPosted: 20:46 - 10 Apr 2010    Post subject: Reply with quote
If the disk was loose wouldnt i feel it pulsing on the lever? or something
Only reason im putting it down to headbearings/forks area, is it only makes the noise when weight transfer happens like hard breaking pushing weight to the front end..
steveh
PostPosted: 22:00 - 11 Apr 2010    Post subject: Reply with quote
Sounds like head bearings, if you can, put your fingers under the top yoke (behind the top nut) and hold the front brake and push forwards, you should hear a bit of a "knock"
Maybe get a friend to give you a hand.
steve.
tutton
PostPosted: 22:05 - 11 Apr 2010    Post subject: Reply with quote
Yeah was the head bearings, got a hammer and cloth wrapped the end up loads, and gently little by little tapped the rings to the right, and its fine now
Cheers all
Handsome
PostPosted: 22:13 - 11 Apr 2010    Post subject: Reply with quote
Ahh, mine's been doing that lately, I'll have a look now I know what it is, had an idea it was that but wasn't 100% sure... Thumbs Up
The last post was made 16 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 15 - Page Size: 65.41 Kb
