gearbox bearings (DT)
MartZ0r
PostPosted: 15:33 - 10 Apr 2010    Post subject: gearbox bearings (DT) Reply with quote
hey guys. i have a little problem
i have had all my engine parts back after weeks of delay, but now i have another issue. i bought some bearings for the primary drive shaft and the counter weight balance shaft bearing. i stuggled to get these bearings but i have picked them up today however they are sealed bearings. i was told they are fine to use openly also? he said you just flip the seals off and clean the grease out. the inside of the bearings has a plastic cage.
the bearing numbers are the same and same manufacture, only they ahve (RS) on the end of the model numbers.
anyone know agree on what the man said?
steven_191
PostPosted: 18:29 - 10 Apr 2010    Post subject: Reply with quote
yeah, the sealed bearing is just an open bearing with a cover on and pre packed with grease.
pull the seal off and you will see inside, all the balls are held together in a ring.
MartZ0r
PostPosted: 19:21 - 10 Apr 2010    Post subject: Reply with quote
thanks for the reply!
the only issue is, i noticed the inner ring is plastic instead of a metal cage. will this effect anything?
steven_191
PostPosted: 19:53 - 10 Apr 2010    Post subject: Reply with quote
same here about the heat.
if in doubt, get the right part Wink
MaybeGuy
PostPosted: 20:10 - 10 Apr 2010    Post subject: Reply with quote
the internal gearbox bearings on an R6 are sealed. its a plastic seal. its not going to melt in engine temp oil.
MartZ0r
PostPosted: 20:14 - 10 Apr 2010    Post subject: Reply with quote
fair point about the heat. how hot would you say they would get? i can test my spare one up to 250 degrees+.
i would get the exact ones its just il have wasted 20 quid in bearings and have to buy more. i have the old ones they are still in good condition with no play and spin freely so i might use those.
cheers
MaybeGuy
PostPosted: 20:29 - 10 Apr 2010    Post subject: Reply with quote
fan kicks in at like 100 degrees which is in summer standstill traffic, and my bike tends to sit at about 78 degrees when riding
MartZ0r
PostPosted: 23:16 - 11 Apr 2010    Post subject: Reply with quote
right, i decided to reuse the old bearings as they were in good condition and i wanted to get moving on all of this, here is the build thread
https://www.bikechatforums.com/viewtopic.php?p=2474336#2474336
thanks for the help guys!
tatters
Exxon Valdez
PostPosted: 00:28 - 12 Apr 2010    Post subject: Reply with quote
Thats the coolant temp which is unrealated, oil temp on a warmed up to hot four-stroke engine is around 90-140 degree, gear box temp on 2-strokes and 4-strokes with seprate gearboxs get around 60-70 degrees.
Dont worry about plastic parts in a gearbox l,ve come across alot in stock BMW gearboxs and most engines have plastic parts in the engine (filter cages/guides/pump gears etc).
MaybeGuy
PostPosted: 01:36 - 12 Apr 2010    Post subject: Reply with quote
what about on an oil cooled bike?
The last post was made 16 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 64.56 Kb
