Changing a throttle cable on a GSF600S
azzaconnor
PostPosted: 12:52 - 10 Apr 2010    Post subject: Changing a throttle cable on a GSF600S Reply with quote
Hi,
How easy is it to change the throttle cable on a GSF600S Bandit (Year of reg 2000). The cable on mine snapped the other night, and its going to be a real hassle to get it to a bona fide mechanic; so I am up for attempting to change it myself. It would appear that only one has snapped. How do I identify which one it is? ie the 'push' or 'pull' cable?
Many thanks in anticipation,
AC
oriel dave
PostPosted: 20:58 - 10 Apr 2010    Post subject: Reply with quote
If the pull one has snapped the throttle won't open, else it's the push one and the throttle should still work. Take the cable ends out of the switchgear and part of the broken cable will come out of its sleeving.
You'll need to take the tank off, then tie the new cable to the front end of the old one and pull it through to make sure it's routed the same way. I'd fit the carb end first as this is more fiddly, be patient and use a tool to wedge the throttle mechanism in a position you want it. Then it's just a case of fiddling the old cable end out and the new one in.
HTH
Europe Trip 2009
The last post was made 16 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 31.59 Kb
