Right... I want to upgrade my Graphics Card!
SonofABiker
PostPosted: 19:16 - 10 Apr 2010    Post subject: Right... I want to upgrade my Graphics Card! Reply with quote
Hi guys.
Im going to hastily admit my pc knowledge is sadly lacking. I've had this pc for a few months now, and although everything is working Fine, im wondering if the graphics card that came with it is a little..lack lustre.
I'll list the specs on this now, and if you see what I can do easily please let me know!
System
Manufacturer To Be Filled By O.E.M.
Model To Be Filled By O.E.M.
Total amount of system memory 2.00 GB RAM
System type 64-bit operating system
Number of processor cores 2
Storage
Total size of hard disk(s) 466 GB
Disk partition (CSmile 409 GB Free (466 GB Total)
Graphics
Display adapter type NVIDIA GeForce 9500 GT
Total available graphics memory 1791 MB
Dedicated graphics memory 1024 MB
Dedicated system memory 0 MB
Shared system memory 767 MB
Display adapter driver version 8.17.11.9621
Primary monitor resolution 1280x1024
DirectX version DirectX 10
Network
Network Adapter NVIDIA nForce Networking Controller
Notes
The gaming graphics score is based on the primary graphics adapter. If this system has linked or multiple graphics adapters, some software applications may see additional performance benefits.
Googling seems to check out the 9600GT for instant upgrade, but I want to buy something that will last for a while so I dont mind spending £100-150 on a card that will last. I mainly play Lord of the Rings online (it currently sits around 30-40fps) and MW2...
Any advice?
Cheers!
I need a break!
SoND
PostPosted: 23:19 - 10 Apr 2010    Post subject: Reply with quote
9600GT isn't a gaming card. Don't go near it.
GTS250 1GB <£100 is very good. If you run it in SLI it can beat a GTX285 in some situations.
Remember you need a good power supply.
SonofABiker
PostPosted: 09:26 - 11 Apr 2010    Post subject: Reply with quote
Noted and duly remembered.
Next incredibly daft question... Power supply? What/how would I know what one I have? Ive been reading and note about 400w or so on so forth...
Mine is an ATX 450.. it says max is 450w. Is this enough?
Cheers for the help so far!
I need a break!
Stowelly
PostPosted: 12:10 - 11 Apr 2010    Post subject: Reply with quote
450 MIGHT be enough. depends what your running off it? if youve got like 4 hard drives, several usb devices and some PCI cards it might not be enough
can forget about running SLI on that psu though
SonofABiker
PostPosted: 08:12 - 12 Apr 2010    Post subject: Reply with quote
I've got one hard drive, and no USB ports or anything really. literally, this pc is just for a couple of games (but I want to put Empire Total War on it shortly) and internet.
Im happy to up it to a different power supply if its needed.
And once more, my knowledge fails me regarding SLI. I'm just loathe to take it to PC world as quite honestly last time they were worse then useless. took them two weeks to fix an issue I found out I could've fixed myself in a minute.
Thanks for the assistance thus far!
I need a break!
SoND
PostPosted: 14:58 - 12 Apr 2010    Post subject: Reply with quote
Don't go to PC World Smile
SLI is when you run two graphics cards alongside each other for increased performance. It requires a beefy PSU and specialist motherboard. You don't need to worry about this.
Gaming cards are very heavy on the 12V rail of your PSU and in a lot of cases the overall wattage doesn't tell you anything.
To find out what your PSU is capable of you will need to remove the side of your case and read the label that will be stuck to the PSU. On the label you will see a list of voltages, +3, +5, +12 etc, and their corresponding amps. Find the +12V and take note of its amps.
There is a chance your supply will be running multiple 12V rails (12V1, 12V2), this is a good thing. If not, don't worry.
Most cards reccommend a 12V current rating of at least 24A.
If your PSU just isn't good enough, below is a budget one that is plenty for you.
https://www.overclockers.co.uk/showproduct.php?prodid=CA-042-OK&groupid=701&catid=123&subcat=
Welshd1k
PostPosted: 00:09 - 13 Apr 2010    Post subject: Reply with quote
ati 4890 monster of a card or for dx11 which the nvidia gtx2xx dont have get an ati 5770 ... you wont regret it
The last post was made 16 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 54.68 Kb
