Putting Bike Chain Through Swing Arm
Leviathan91 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
TheDonUK
PostPosted: 14:29 - 11 Apr 2010    Post subject: Reply with quote
Probably, but then they would only need to undo your rear axel nut, remove the wheel, slide of chain (and if they have time put back wheel).
Saying that whenever i have chained bikes its been through the wheels which is even less secure.
For maximum security somewhere on the frame?
johnsmith222
PostPosted: 15:12 - 11 Apr 2010    Post subject: Reply with quote
How are they going to slide off the chain if it's through the wheel and swingarm and attached to something solid?
See there is a "hole" in the swingarm. It'd be best to put it though that and the wheel.
Unforetunately my bike doesn't have a hole like that in the arm. Sad
imanupstart
PostPosted: 17:28 - 11 Apr 2010    Post subject: Reply with quote
Swingarm, wheel and pillion peg hanger if it will reach Wink
TheDonUK
PostPosted: 18:32 - 11 Apr 2010    Post subject: Reply with quote
I suppose you are right, with the title of the thread i had assumed the OP meant just thru the swingarm.. /shrug
iooi
PostPosted: 19:37 - 11 Apr 2010    Post subject: Reply with quote
Where ever you can. But through a solid part of the frame would make more sense.
The weak point is not them unthreading the chain. Its how easy it is to cut......
Oh and make sure its attached to something solid, so it can't simply be lifted up into a van Thumbs Up
Quote Me Happy
PostPosted: 20:00 - 11 Apr 2010    Post subject: Reply with quote
Have you had a look at the Anti-Pinch Pin? That way you can lock your bike through the frame.
Best used with the Squire Lock on the site and a ground anchor.
Have a look at the packages of chain, lock and anchor on that site. People look in horror at spending nearly £300 but think nothing about spending it on farkles for their bike. Getting some decent security is a good investment if you plan on owning bikes for a few years.
The last post was made 16 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 56.41 Kb
