brake bleeding
Bubbs
PostPosted: 16:52 - 11 Apr 2010    Post subject: brake bleeding Reply with quote
Hi guys,
Just installed new brakes and had to bleed the brakes afterwards. Just wondering how long it takes for the brakes to stop being spongy? They currently stop me but not very well. Is this normal or do you think the brake fluid might still be aerated?
First time I've ever done this so I'm far from competent.
All replies are appreciated...well unless you call me a cvnt
Itchy
PostPosted: 16:58 - 11 Apr 2010    Post subject: Reply with quote
They shouldnt feel spongy at all, when I bleed them on CBR or what ever the brake lever is uber firm.
In that I bleed them on each caliper then again, then shake the calipers then bleed them at the mster cylinder then if I am not in a hurry tie the lever to the bar leaving it overnight and come back in the morning and all air should be done.
Kaph
PostPosted: 18:26 - 11 Apr 2010    Post subject: Re: brake bleeding Reply with quote
Bubbs wrote:
Hi guys,
I did mine t'other day after many problems. If they are spongy there is still air in the lines.
HTH
Bubbs
PostPosted: 18:47 - 11 Apr 2010    Post subject: Reply with quote
Right ok.. They feel a lot better than they did but still not brilliant. I'll do it again me thinks.
The Artist
PostPosted: 18:50 - 11 Apr 2010    Post subject: Reply with quote
Liquid doesn't compress so if it is spongy, 99% of the time it will be air in the system.
Just make sure you are doing it right! Some people are squeezing the lever at the wrong time etc. There is a sticky about it at the top of the workshop.
steven_191
PostPosted: 21:31 - 11 Apr 2010    Post subject: Reply with quote
if your still not getting it sorted try unbolting the caliper and moving it around freely to ge the fluid inside moving, might just have a stuck air bubble.
The last post was made 16 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 48.23 Kb
