R1 CLUTCH SQUEAK
fraseb01
PostPosted: 22:15 - 11 Apr 2010    Post subject: R1 CLUTCH SQUEAK Reply with quote
Hi all,I recently changed my oil and filter on my 2000 r1,i done 100 miles today and from the start i was getting a squeak from clutch side when downshifting only(no other probs at all only squeak) does anyone have any ides,oil over fill,clutch basket? any advice would be great. Very Happy
Bike - GSXR 600 K3
TUG
PostPosted: 23:00 - 11 Apr 2010    Post subject: Reply with quote
Did you check the oil propperly afterwards, when you fill the oil after fitting a new filter about 200ml will be drawn into it lowering your level.
It might be a clutch cable adjustment issue, but i doubt it, did you change anything else?
Haz ER-5, innit!
fraseb01
PostPosted: 07:04 - 12 Apr 2010    Post subject: Reply with quote
nothing else changed just oil and filter,if anything i think there might be a little too much oil,will this cause me an squeak issue?
Bike - GSXR 600 K3
cb1rocket
PostPosted: 13:25 - 12 Apr 2010    Post subject: Reply with quote
I imagine the R1 clutch is hydraulic operated? Has the lever been oiled with wd-40 or similar?
Bishbash
PostPosted: 13:35 - 12 Apr 2010    Post subject: Reply with quote
It is cable Wink
Where does the squeek come from? any particular area? Is it the shifter? lever? Towards the engine?
fraseb01
PostPosted: 16:05 - 12 Apr 2010    Post subject: Reply with quote
seems to come from engine area.
Bike - GSXR 600 K3
Bishbash
PostPosted: 14:58 - 13 Apr 2010    Post subject: Reply with quote
If you can get a video up or something I might be able to help you, I cant pinpoint anything from this info. Thumbs Up
Fortuna
PostPosted: 19:12 - 13 Apr 2010    Post subject: Reply with quote
Mine did this, turned out that I had disturbed the exup valve.
The valve alters with the revs, so when downshifting it was moving.
fraseb01
PostPosted: 19:38 - 13 Apr 2010    Post subject: Reply with quote
how did you fix it,do you think i might have trapped the valve cables when replacing bodywork?
Bike - GSXR 600 K3
The last post was made 16 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 59.53 Kb
