Recommend me a fuel system cleaner
jimspeed
PostPosted: 09:45 - 13 Apr 2010    Post subject: Recommend me a fuel system cleaner Reply with quote
i think i need to run something thru the carbs on my bike to just help clean the sytem a bit after it been stood for 2 years.. any recomendations.. redex etc..
tried and tested solutions please without dismantling the bike
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
el_oso
PostPosted: 09:52 - 13 Apr 2010    Post subject: Reply with quote
i have used redex before with good results.
Duke 390
Car: Jeep Wrangler 4.0L
temeluchus
PostPosted: 10:52 - 13 Apr 2010    Post subject: Re: Recommend me a fuel system cleaner Reply with quote
If its sat with fuel in the carbs (assuming its a carbed bike) redex will do nothing. The varnish will need proper cleaning (and therefore stripping of the carburettors).
If they were drained when it was stood, then you shouldnt need anything other than fresh fuel to get it going.
andys675
PostPosted: 12:25 - 13 Apr 2010    Post subject: Reply with quote
silkolene FST (fuel system treatment)
stick a 2% mix in with a tank of fuel, then 1% the tank after, but needs to be in a tank of fuel that you use slowly, it won't work if you go and use the tankful in one day it needs to lie in the system for a good week
used it on my 350 ypvs and afterwards the thing would just sit there ticking over quite happily instead of needing constant throttle blipping just to keep it running
temeluchus
PostPosted: 20:50 - 13 Apr 2010    Post subject: Reply with quote
most of the additives ate 99% paraffin, which does help shift water out of nooks and crannies.
If you want to stick something in the tank, chuck half a cup of paraffin in the tank.
jimspeed
PostPosted: 21:12 - 13 Apr 2010    Post subject: Reply with quote
ok thanks for the advice guys.. i have not long bought the bike, she runs ok but is a bit random on idle and at low rpms (3k ish). i have balanced the carbs (see other thread) and its better but i think there may be a bit of something in the idle jets on the one carb. think i'll try the redex or silkolene stuff and see how it goes for a bit as i dont think its going to hurt
whats the chances of there being a filter on the fuel pipe or the fuel switch??
The last post was made 16 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 48.75 Kb
