Drive train sprocket carrier worn?
Cigaro
PostPosted: 14:08 - 11 Apr 2010    Post subject: Drive train sprocket carrier worn? Reply with quote
Hi all,
took the GN for its MOT today
One of the things my bike failed the MOT on was this:
"DRIVE CHAIN SPROCKET CARRIER WORN TO EXCESS (6.2.1e)
The guy at the bike shop says it needs to be repacked and adjusted. Is there a seperate bearing in the sprocket carrier then? What do I do?
Also both rear shocks are inneffective, is there anything that can be done to repair them? New ones ar eonly £50 but I'm a bit broke right now...
cheers.
PostPosted: 16:45 - 11 Apr 2010    Post subject: Reply with quote
Sprocket carriers don't wear out what's he saying is wrong with it exactly?
serlant
PostPosted: 16:55 - 11 Apr 2010    Post subject: Reply with quote
cush drive possibly? if its that and you can't get a new one you might be able to pack it with slices of inner tube to sort it till you can get a new one.
The Artist
PostPosted: 17:01 - 11 Apr 2010    Post subject: Reply with quote
The sprocket carrier has a separate bearing inside it. Very little movement but I have had one fail on a cbr125.
Best bet is taking the chain and rear wheel off. The sprocket and carrier will fall out. Just check the cush drive rubbers. If they are fine, check the bearing inside the carrier.
Cigaro
PostPosted: 17:16 - 11 Apr 2010    Post subject: Reply with quote
Cheers, he mentioned cush drive rubbers but when he mentioned repacking i switched off and assumed he was on about a bearing.
So repacking the rubbers should be alright?
I'll check for play anyway, do I just see if the sprocket moves slightly with the wheel in place and spindle on?
TheDonUK
PostPosted: 17:34 - 11 Apr 2010    Post subject: Reply with quote
If it is the cush driver rubbers get them replaced, i was told mine were shagged months ago and i just ignored it, i strongly suspect it was their deterioration that caused the catastophic failure of the rear hub coming out, and the sprocket carrier smacking into the swingarm, locking the wheel at 40 Sad
The Artist
PostPosted: 17:42 - 11 Apr 2010    Post subject: Reply with quote
The rear sprocket should have a little play in it to allow for shocks in the gearbox to prevent loosing traction and damage to chain etc.
MOT tester probably just shook the sprocket and thought it moved too much.
Just take the wheel off. Not a big job and have a look at the rubber. New rubbers are only a few quid off wemoto or ebay.
Cigaro
PostPosted: 19:08 - 13 Apr 2010    Post subject: Reply with quote
Well, the rubbers look a bit buggered, but the bearing has LOADS of play in.
Looks like I'm going to have to replace it.
Thanks for the help all.
PostPosted: 09:45 - 14 Apr 2010    Post subject: Reply with quote
Get the bearing from a bearing shop, should be loads cheaper. Take the whole carrier down there and get them to match it. If you are too tight/skint to buy cush rubbers just pack them out with strips of inner-tube rubber.
Cigaro
PostPosted: 10:18 - 14 Apr 2010    Post subject: Reply with quote
Managed to sort out some new rear shocks, a cush drive rubber and a new bearing for £70 all in, which I didn't think was too bad.
My friends and family all think I'm mental for keep throwing money at this old jalopy Laughing
Cigaro
PostPosted: 10:24 - 14 Apr 2010    Post subject: Reply with quote
Question: to change it do I just remove the dust seal and circlip, take the inner out and tap it out like a wheel bearing on a car?
Cheers Very Happy
The Artist
PostPosted: 11:47 - 14 Apr 2010    Post subject: Reply with quote
I would have thought it was a sealed bearing so just get a punch and tap the outer race either side and it should come out.
The last post was made 15 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 69.69 Kb
