NSR (99) cooling
Skvara
PostPosted: 23:49 - 07 Jul 2004    Post subject: NSR (99) cooling Reply with quote
This is my very first topic, I've got a NSR 125 R (99) and I don't know where to fill water or something for cooling my motor!!! I've got it for a month but I am afraid to damage it!!! Sorry for my English, I am from Czech republic Smile
tatters
Exxon Valdez
PostPosted: 23:59 - 07 Jul 2004    Post subject: Reply with quote
radiator resvere is located under the fuel tank to the left and has a rubber cap with a small pipe going into it you need to fill this to the fill line with 50% water and 50% anti freeze.
to learn more about serving the NSR go to Korns fabilous site www.nsr125.com
Skvara
PostPosted: 01:09 - 08 Jul 2004    Post subject: Reply with quote
Is it needed to fill it with anti freeze if it's summer??? Very Happy And for how long it should be filled??? I've got my bike about a month so I didn't do this before! How often have it to be checked???
tatters
Exxon Valdez
PostPosted: 14:14 - 08 Jul 2004    Post subject: Reply with quote
always use anti-freeze it will be winter at some point and you never need to change it just top it up over the years
mr jamez
PostPosted: 15:42 - 08 Jul 2004    Post subject: Reply with quote
Anti freeze also acts as a summer coolant for the water. Use de-ionised water as well it seems to help with fur and corrosion, you can get it from halfords or DIY stores Smile
alains
PostPosted: 16:38 - 08 Jul 2004    Post subject: nsr cooling Reply with quote
if you ride in town during summer at very low speed , sometime your temperature indicator will go in the red zone . you must stop for a while or you will broke the piston . if it does it often i will recommend to adapt an electric motor in front of the radiator with either a simple switch or a thermometric contact fit somewhere in a
pipe . power consumption will be around 30-40 watts under 12v
keep an eye on your temperature !
tatters
Exxon Valdez
PostPosted: 18:52 - 08 Jul 2004    Post subject: Reply with quote
or fix your bikes water pump Rolling Eyes
tatters
Exxon Valdez
PostPosted: 18:55 - 08 Jul 2004    Post subject: Reply with quote
alains, your bike is overheating if that is happening and could be water pump not working/ wrong timing/ cyclender head gasket, get it sorted or you will warp you piston/barrel and it will seize
alains
PostPosted: 19:25 - 08 Jul 2004    Post subject: Reply with quote
everybody is right , but try to run in Paris during mid-july as well in most of UK big cities , you will see that hapenning
Skvara
PostPosted: 19:30 - 08 Jul 2004    Post subject: Reply with quote
Thank you all for your tips!!! I have found it Smile Now I am sure, it will not be empty Smile
The last post was made 22 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 64.23 Kb
