scooter not startin
con
PostPosted: 14:15 - 16 Apr 2010    Post subject: scooter not startin Reply with quote
hi, ive got an mbk stunt it nipped up on me, so i got new barrel piston rings, put it all back together made sure rings were in right place, made sure piston moved smoothly up and down barrel everything ok, wen to start it up and it will not start wot so ever cheked spark just wont start any advice people lol?? thanks
con
The Artist
PostPosted: 14:32 - 16 Apr 2010    Post subject: Reply with quote
To start it needs fuel, compression and a spark.
If you have a spark, check you have compression by putting thumb overplug hole and turning engine over. It should blow your thumb off with no problem.
If you have compression check fuel by pouring a small amount of fuel into the cylinder through the spark plug hole, put the plug back in and try and start. If it revs up and then dies after a few seconds it means fuel is not getting into your cylinder which is a carb issue.
Do these then tell us what happens
The last post was made 15 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 31.39 Kb
