| Robby |
 Robby Dirty Old Man
 Posted: 12:00 - 16 Apr 2010 Post subject: Getting a decent paint job done |
As dedicated followers or Robby will know, I spent rather a long time restoring a CB250RSA. Restoration doesn't perfectly explain the process however, because I did my usual job of impeccable mechanicals and poor cosmetics - see pic.
https://www.bikechatforums.com/files/09042010532_1_.jpg
I painted the frame with hammerite, having de-rusted it first. It seems that de-rusting it isn't a great idea, the hammerite doesn't stick to good metal as well, but it was necessary so I could find the bits where it had rusted through and sleeve them (for the geeks, details of how I sleeved it below).
The real problem is the bodywork. That crap red paint job you see there ended up costing me over £200 in paint stripper, wet and dry, undercoat, colour coat, decals and lacquer. It also took about 50-100 hours of work over 3 months. It isn't particularly hard, the lacquer lifted one of the decals, it's generally crap.
So, who can recommend a bike painter that they have used (don't say dream machine if you haven't used them). I want to get an original paintjob, or close enough to look it. For instance, if the original paint is hard to obtain or very expensive, I can go for a slightly different one. I'm not particular about if the decals are stickers or painted, and I don't want to do a single bit of prep. Time isn't important because I have a spare good set of bodywork to get painted, but it will need the old paint stripping or whatever they do first.
Also, if you have had a paintjob done, say what bike and what it cost. If it's very expensive I'll try and find a local car sprayer and give them precise instructions.
For anyone contemplating their own spray job, who hasn't done it before, here are a couple of recommendations and my costings.
Buy a compressor. I used rattle cans. A compressor is a tool you need, you just don't it. I need to get one. Rattle can paint is also very expensive for what you get.
Buy a book on doing bodywork, read it cover to cover before you begin. I didn't, and still haven't. I should have, because on my 30 year old bike there is mild steel, stainless steel, chrome, aluminum alloy, at least two types of plastic, possibly some cast iron (rough, could just be cast steel) and lots of rust.
Build yourself a home spraybooth and use a mask. I didn't, I sprayed in my garage on a workmate. I blew my nose and paint came out, lots. I could have made basic booth using wood that was lying around and plastic sheeting or old bedsheets for the sides.
When stuff is drying, make sure it's out of the way and stable. My dad knocked over the freshly painted tank, didn;t say anything, and put it back. I came back down the following week to check on it, and was confused by fresh scratches in my fresh paint. If you live with your parents, or use their garage, remember how clumsy at least one of them is.
Anything involving filler will be a horrible screaming nightmare. It will look and feel glassy smooth, but once the colour coat goes on it'll show horrible deep scratches and an outline.
Costings. This is going to be painful. Mostly bought from halfords.
Paint stripper - £40
Wet and dry paper - £15
Filler - £5
Primer - £15
Filler primer - £40 (sigh)
Colour coat (red) - £40
Lacquer - £20
Decals - £60
Total - £235
You may notice that I bought enough paint to do a car. This is because I had to keep taking it off and doing it again. |
| Damon |
 Damon World Chat Champion
 Posted: 18:35 - 16 Apr 2010 Post subject: |
First mistake you made is using halfords cans. Shit paint and bloody expensive.
You should pop to a local car paint place and get them to make up some 2k areosol cans. They usually work out at about £12 a can, but the paint is the same as you use in a compressor. 3 cans normally will do a full bike.
Also, top tip when spraying is to warm up your cans in warm water before spraying. Makes such a difference Try spraying with a cold can and then with a warm can, you will see what I mean |
| gmanxiii |
 gmanxiii World Chat Champion
| everyreasonto |
 everyreasonto Nitrous Nuisance
| Clanger |
 Clanger Stirrer
| BanditsHigh |
 BanditsHigh Worse than a woman
| G |
 G The Voice of Reason
| ms51ves3 |
 ms51ves3 Super Spammer
| ZRX61 |
 ZRX61 Victor Meldrew
| Robby |
 Robby Dirty Old Man
| Howling TerrorOutOfOffice |
| DrDonnyBrago |
 Posted: 13:48 - 17 Apr 2010 Post subject: |
How did you get the black chequered bits on it? looks awesome if you did that bit yourself! |
| DrDonnyBrago |
 Posted: 13:49 - 17 Apr 2010 Post subject: |
| Dazbo666 |
 Dazbo666 World Chat Champion
| BanditsHigh |
 Posted: 18:57 - 18 Apr 2010 Post subject: |
^^^ Spot on ... black base coat, then fishnets (on the tank not me) and BMW Midnight Blue metallic, then mega amounts of lacquer to bring the finish up to the same level as the Suzuki 'S' so that when rubbed down it was flush  |
The last post was made 15 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
