| DrDonnyBrago |
 Posted: 15:06 - 19 Apr 2010 Post subject: Handlebar vibration and knocking |
Two questions, bike is a 2001 CBR 600F (fuel injected):
1.
My bars vibrate a lot esp at speed, getting dead fingers after longer journeys... any thoughts on what I should be looking for?
I was thinking wheel bearings (checked they seem fine), tire balancing etc. Should I sync my throttle bodies?
2.
I also have a rythmic 'knocking' coming through the bars at lower speeds, the frequency increases with speed up to about once or twice a second then I can't feel it anymore. I worked out a tight spot (or several )in my chain not long ago and I thought it went away, not sure if it has come back or I just stopped noticing it.
Say I am riding at 30mph; with the clutch out and in gear i can feel the very slight bump in the bars; with the clutch pulled in it stops, if I pull the clutch and rev it to the same rpm it doesnt start knocking again... any ideas? |
| DrDonnyBrago |
 Posted: 15:09 - 19 Apr 2010 Post subject: |
Ah thought I should add, my front brakes seem to drag quite a lot despite my attempts at cleaning them.
Cheers  |
| Wu_Dan |
 Wu_Dan L Plate Warrior
| neil. |
 neil. World Chat Champion
| chris-red |
| DrDonnyBrago |
| neil. |
 Posted: 16:39 - 19 Apr 2010 Post subject: |
Grab the wheel and pull it from side to side, diagonally (push the bottom, pull the top, sideways to try and bend it). There should be no play/knocking which would indicate bad bearings. How old are your C&S/how many miles on them?  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| DrDonnyBrago |
| DrDonnyBrago |
| chris-red |
| DrDonnyBrago |
 Posted: 21:48 - 19 Apr 2010 Post subject: |
yeah the rear seems ok, the front is less great but I didnt photo it. The chain is by far the weakest link (see what I did there ) though, recently it had loads of stiff links (could barely move them by hand) so it is due replacing soon. |
| cloric_tzr |
 cloric_tzr Brolly Dolly
| cloric_tzr |
| Wu_Dan |
| DrDonnyBrago |
 Posted: 09:38 - 20 Apr 2010 Post subject: |
I dont care if the advice I get is from your great grandma's cookbook nso long as it is applicable
Cheers all
I was reading up about handlebar virbation and a thread was mentioning that carb balancing can alleviate it. Obv I dont have carbs on an FI bike but you can still balance throttle bodies - worth buying a set of vacuum gauges? |
| DrDonnyBrago |
 Posted: 19:16 - 20 Apr 2010 Post subject: |
| The Tot |
 The Tot World Chat Champion
 Posted: 20:07 - 20 Apr 2010 Post subject: |
Right,
Hondas in particular haven't been known for the quality of their drivetrain. My 929 blade gets knocking from the front sprocket despite the chain being in good condition, tensioned correctly and sufficiently. It's just honda's nature to have rattly clutches in town when its below 3k rpm.
The juddering from a warped brake will be prevalent at low speeds because you'd feel the thudding whereas braking from high speed, the frequency of the wheel rotation will give the sensation that the lever is hovering despite applying constant force. When was the last time you cleaned the calipers? If the pads are dragging, strip your calipers and give them a thorough clean - there's plenty of useful guides in the workshop section by Korn. How hot does the brake disk get under normal use (NOT after ragging it on your twisties). If it's hot to the touch, then it's very likely that the constant cycling heating cooling has caused it to warp. I recently had to change my discs after they warped over winter! The irony is that changing the pads (I use Honda original NISSIN HH pads), bleeding the brakes and cleaning them made the problem worse. The levers were rock hard as you'd expect, but it only exacerbated the symptoms.
Solution
https://www.calsport.co.uk/HONDA/3253-2000-CBR_600_F_FXFY/32-Brakes__Wheels/Galfer_Wave_DiscsLinesPads/73172
They were cheaper than getting a set of genuine spares from davesilverspares and they're wavy. I didn't buy them for the bling, I bought them to see if their claim of reduced chance of warpage would be true. I'll know after another 10 years of use I suppose. Granted your bike is 9 years old, you can expect the discs to be past their best so this is a good investment - you'd get the pads as well. They don't take a long time to warm up and they're good in the wet. So from me.
Vacuum gauges? I'm not too sure if that's relevant to a non-carbed bike since fuel injectors don't rely on vacuums to pull the fuel air charge through. It's all electrickery when it comes to synchronizing fuel injectors. Have you checked your air filter to see if it hasn't been pierced? Exhaust blowing? The CBR600's came with mild steel headers so they'll inevitably rot! ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| DrDonnyBrago |
 Posted: 20:51 - 20 Apr 2010 Post subject: |
| The Tot wrote: | Right,
My clutch whines like a bitch in 1st but the buzzing is different, i.e. at 7k on Mway it makes my hands go a bit dead, its very high frequency. I think the knocking is my chain tbh as it gets faster as i increase speed and I think it stopped when I freed up loads of links a month ago - need to check to see if any are re-siezed really.
Is your knocking gearbox related then?
The brakes work really well, I cleaned them about 3 weeks ago, I didnt take the pistons out as I didnt want to replace the fluid but I pumped them out very far and cleaned the whole area with brake cleaner and a tooth brush then red rubber greased the pistons and stuck the calipers back on. The levers are nice and firm and the brakes are progressive and non juddery at any speed - no hovering or juddering when I am braking. I can however still hear them rubbing the discs when pushing the bike forward or spinning the front wheel by hand. I hear that all bikes bind a bit, but I dont have any previous bikes to compare to. Good idea on checking the discs for heat after a non mentalist ride, will do that
Solution
Will bear those in mind in future, but if I can avoid spending £350 I will
Vacuum gauges? I'm not too sure if that's relevant to a non-carbed bike since fuel injectors don't rely on vacuums to pull the fuel air charge through. It's all electrickery when it comes to synchronizing fuel injectors. Have you checked your air filter to see if it hasn't been pierced? Exhaust blowing? The CBR600's came with mild steel headers so they'll inevitably rot! |
I checked my air filter about 1000 miles ago and my pipes were rusted through but I puttied them, no leaks now and I check them regularly.
FI bikes still need the TBs syncing, I just dont know if out of sync TBs manifest themselves as the buzzing I am getting, would have thought it would be lower frequency? https://cbrforum.com/forum/showthread.php?t=42239
Cheers for the post buddy  |
| The Tot |
 Posted: 22:19 - 20 Apr 2010 Post subject: |
Err,
I forgot to ask, do you have any bar end weights?! The answer could be as simple as this! Get some bar end weights to dampen the vibrations through the bars! Not the cure but one way of eliminating the symptoms. I noticed my left hand had a bit of a pins and needles sensation when i replaced the handlebar due to a crash - the replacement bar had no bar end weight so it was lighter. If you're au fait with resonant frequencies etc, then a heavy bar end weight (i.e. OEM) will dampen the frequency of the vibration or shift it out of the resonance band when you're at speed.
CHECK THIS first because it'll be only a 10 quid fix as apposed to a £350 set of discs etc.
If your bike drives fine through the rev range then your bike is fine. i'd either get Stainless steel headers as a replacement because the problem of puttying won't hold in the long run. Just a heads up for after winter when you get a greater temperature gradient due to the cold.
Brakes are meant to bind a little. I notice it after a ride. It makes a swoosh swoosh swoosh sort of sound. Totally fine after a ride. As long as you've cleaned your calipers and are happy with the action, then you're fine. Brake discs are fully floating i.e they're designed to have a bit of play - if you look at the discs you'll see that the disc itself is mounted onto the carrier with rivets/buttons which are meant to have some play in it. A little rubbing is fine. If you find they get hot even without applying the brakes, then something is wrong.
I guess with any new bike, just get used to its traits and characters. I've ridden my mate's CBR600F-S of similar vintage to yours and I have to say that it's almost similar to my 929 blade. So, really there's nothing to worry about. Bikes will age, some quicker than others, so you'd need to make account of consumables.
But yeah, CHECK YOUR BAR ENDS! ____________________ The Tot 2019 Z1000SX - 2007 R1
| DrDonnyBrago |
 Posted: 22:28 - 20 Apr 2010 Post subject: |
I have the OEM bar ends in, I spent about 4 hours polishing them 3 weeks ago
I know the pipes are shite, but I'm all for cheap running of the bike where possible - I have been eyeing up some new StSt ones but having trouble finding cheap ones with balance pipes on. Heard about midrange stutters with some non oem ones too. Money would be better spent on new chain and sprockets at the moment I think
I have a list of stuff to check next weekend so I'll report back if any of it makes a fudge of difference. In the meantime if anyone knows anything about TB syncing or has anything else I should check let me know  |
| cloric_tzr |
| DrDonnyBrago |
 Posted: 20:34 - 21 Apr 2010 Post subject: |
Being as tight as a nun's cunt is the way forward  |
| cloric_tzr |
The last post was made 16 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
