| Mr White |
 Mr White Renault 5 Driver
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 23:29 - 20 Apr 2010 Post subject: |
Most 600cc engines are about 60-65kg in weight, two people should be able to get that back in using a jack and bodging some stands etc.
I can't help with the paint  |
| el_oso |
 el_oso World Chat Champion
 Posted: 23:53 - 20 Apr 2010 Post subject: |
i have taken the engine out of my divvy by myself. it wasn't easy with one person but do able.
it was very easy very with two people.
stick a couple of wooden blocks under the engine and a towel on the frame. make sure you take the oil filter off. it is next to impossible to get it out with the oil filter on. but with two people and the oil filter off very easy. slides straight out.
you can achieve a good finish with the rattle cans from halfords. however it can get quite expensive. i'll try and take a picture of the gpz500 that i have just resprayed in black
exhaust painting
why not just give the exhaust a good clean of all rust and polish using some wire wool or similar to remove all the crap then use a drill with a polishing bit on it and polish her up ____________________ Duke 390
Car: Jeep Wrangler 4.0L |
| Frost |
 Frost World Chat Champion
| Mr White |
| TQ |
 TQ Trackday Trickster
| DrDonnyBrago |
| Mr White |
| mad4it028 |
 mad4it028 World Chat Champion
 Posted: 15:34 - 21 Apr 2010 Post subject: |
if you clean the down pipes with autosole they will clean up fine theres no rot on the down pipes more of a light brown film p[aints dont last on down pipes as they get too hot  ____________________ always looking to buy bikes crashed ,unfinished projects,none runners pm me
currently riding kawasaki z1000 only bike ive ever loved |
| chris-red |
| Mr White |
| mad4it028 |
| el_oso |
| DrDonnyBrago |
| Mr White |
| Mr.Everready |
 Mr.Everready World Chat Champion
 Posted: 10:50 - 22 Apr 2010 Post subject: |
I think the hammered finish would look really bad. Get it powdercoated.  ____________________ the undemocratically unelected mod of the Scottish section |
| Cigaro |
 Cigaro World Chat Champion
 Posted: 11:30 - 22 Apr 2010 Post subject: |
I've found the easiest way to remove/replace engines is with the wheels off and the frame resting flat on the ground. Then you don't have to faff about with lifting/supporting the engine and there's less chance of dropping it!
I've had the engine out of my GN twice, the first time it was on its wheels and it took me hours with a helper, second time wheels were off and bike resting flat on the ground, took me 10 minutes and i was on my own too.
Try it next time, you'll save a load of hassle for an extra half an hour's work  |
| Mr White |
 Posted: 12:17 - 31 May 2010 Post subject: UPDATE |
UPDATE
Bike is in parts now, only engine and wheels (thus forks as well) left on its place.
I decided not to take the engine off. There is plenty of room to paint the frame with the engine still on.
Questions:
Paiting
I am goint to paint the frame with hammerite direct to rust metal paint, however I am going to clean it from the rust first
I have a large can of red premier oxide , should I give it a coat or two before final hammerite coat?
I want the paint to be more resistant, what lacquer should I use?
Cleaning, Polishing
I want to clean and polish the foot rests, exhausts and exhausts pipes. I got some wire wool, medium and fine.
What is the difference between a rubbing compound and an Autosol? ____________________ Assasination of the leadership of Poland, shots fired at survivers of the plane crash.
https://www.youtube.com/watch?v=FEx7HL4H5yk&feature=player_embedded WATCH IN 480P RESOLUTION TO SEE ALL THE DETAILS |
The last post was made 15 years, 248 days ago. Instead of replying here, would creating a new thread be more useful? |
