Checking valve clearances
DrDonnyBrago
PostPosted: 21:12 - 22 Apr 2010    Post subject: Checking valve clearances Reply with quote
When checking valve clearances on i.e. a 600cc IL4 do you NEED to remove the cam chain tensioner?
Haynes says you should, service manual says you should... I can't really see why? Is there play in the camshaft bearings that makes the gap smaller when the cam chain tension is applied?
I would have thought it would be best to leave the chain under tension so it doesnt slip a tooth when being checked (obviously not applicable if you need to change a shim etc).
What do you all do?
The Artist
PostPosted: 21:27 - 22 Apr 2010    Post subject: Reply with quote
No
CCT would not affect the valve clearances.
The last post was made 16 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 30.93 Kb
