Montesa 348 needs help!
Zedxfarin
PostPosted: 20:15 - 23 Apr 2010    Post subject: Montesa 348 needs help! Reply with quote
I have just got my hands on a cota 348 and i'm trying to get it going. Its not sparking from the plug. If i pull the plug out and hold the lead from the igition coil to the frame it DUZ spark. After this i place the spark plug back and theres no spark from the spark plug!!
Whats up with this its agravating me for days. The thing sparks direct from the lead but wont spark, spark plugs AHAHAH Mad
Montesa Cota 350cc, Yamaha DTr 125cc, Yamaha Timberwolf 250cc, Yamaha YZ 250cc, Kawaski kmx 125cc, Kawaski kmx 200cc, Yamaha TY80cc, 175cc Chinese Dirt Bike, Chinese Wanyge 125cc, Mini & Midi Moto 50cc - What i have owned.
Blue_SV650S
PostPosted: 20:20 - 23 Apr 2010    Post subject: Reply with quote
Have you tried a new spark plug???
Also 2-strokes tend to oil plugs up ... try 'cooking' the plug on a gas hob for a bit!! Thumbs Up
PostPosted: 20:27 - 23 Apr 2010    Post subject: Reply with quote
+1 for new plug.
Chances are it's half knackered and can't spark under compression.
Zedxfarin
PostPosted: 20:33 - 23 Apr 2010    Post subject: Reply with quote
New NGK spark plug orderd & New NGK Resistor Cover.
I will let you know how i get on.
Blue_SV650S
PostPosted: 20:39 - 23 Apr 2010    Post subject: Reply with quote
If it sparks from the cap, then a rogered plug is all it is - so no panic, you will be out again soon fella!! Thumbs Up
p.s. Any pics of the bike (I have a bit of a keen interest in trails bikes!! Smile).
Zedxfarin
PostPosted: 16:51 - 24 Apr 2010    Post subject: Reply with quote
ok you asked for it Blue, It sparks direct from the red lead. But when i conect the plugs and caps theres nuthing.
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00336.jpg
Ok so what your looking at now is a erly to mid 70z twin Shock Montesa cota 348. I was laffing when you said i would be out again soon as i'v never had it running EVER! LOL
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00338.jpg
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00340.jpg
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00342-1.jpg
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00341.jpg
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00339.jpg
Blue_SV650S
PostPosted: 17:24 - 24 Apr 2010    Post subject: Reply with quote
Very Happy
Have you tried a new/another plug yet?!!? Smile
Zedxfarin
PostPosted: 17:59 - 24 Apr 2010    Post subject: Reply with quote
I ordered a new plug and NGK cap. I'll let you know how i get on.
Zedxfarin
PostPosted: 15:28 - 28 Apr 2010    Post subject: Reply with quote
The new plug and cap arived today. Sadly still no joy. Confused
When i got the bike i was told to get a new Wood Ruff jey for the fly wheel. But the thing sparks on the red lead so i never ordered one. Do you think a new Wood Ruff key would help?
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00362.jpg
Blue_SV650S
PostPosted: 17:02 - 28 Apr 2010    Post subject: Reply with quote
The woodruff won't make it spark ... but it will make it spark at the right time Wink
Basically if the woodruff key is missing, the flywheel MIGHT spin on the shaft, therefore putting the ignition timing out ... but that is all it will do ...
I don't see how i you are getting a spark from the lead that you won't get one from a new plug ... how 'strong' is the spark from the lead? What sort of distances will the spark travel and what colour is the spark?
A bit of vid would help here if you have the facilities Thumbs Up
Zedxfarin
PostPosted: 21:08 - 28 Apr 2010    Post subject: Reply with quote
Ok so i went out to make a video for ya and now its not sparking from the red lead ether. I'v just taken a step backword. asny sugestions.
Blue_SV650S
PostPosted: 21:21 - 28 Apr 2010    Post subject: Reply with quote
First check the flywheel is turning ... lets face it, if the previous owner mentioned it, the old one is deffo fecked/missing so the flywheel might be spinning on the end of the crankshaft!! Wink
Next, check the connectors to the coil, you might have a loose one or the wires that go in were only down tothe last couple of strands and now broken completely ...
Zedxfarin
PostPosted: 21:30 - 28 Apr 2010    Post subject: Reply with quote
I was thinking of replacing the wiring. Were could i get new wires for such an old bike Neutral
Since getting the bike i have been looking for a wood ruff key for it. I contacted in motion but thay have been low in helping me to be honest.
finpos
PostPosted: 22:28 - 28 Apr 2010    Post subject: Reply with quote
Sounds like the first thing you should do is check for continuity on the coil. You should be able to find the HT terminal (end of the red lead), the low tension terminal (probably the blue crimp connector on the back) and an earth. Get a meter and measure the resistance between all 3, you should get a reading on all of them (not open circuit). If that's ok you can try and find the actual values in the manual somewhere. Then try again with the cap on.
A woodruff key will not stop your flywheel from rattling around on your crank, it's only there to make sure it's aligned properly during assembly. After that, it's the interference fit of the flywheel on the tapered shaft that holds it in place. If that fails, THEN the forces of the flywheel act on the woodruff key and destroy both it and the slot it sits in. To fix the problem you can variously try a new bolt, lap the flywheel onto the crankshaft with grinding paste, stick it on with special loctite which is made for doing exactly that, or all three if you are paraniod.
f.
Gazdaman
I did a trackday!!!
PostPosted: 12:49 - 29 Apr 2010    Post subject: Reply with quote
Replace the HT lead. It's cheap and will rule out a major possibility.
Make sure the connections are good between the HT>coil and HT>Plug cap and Plug cap>Plug.
Once you've ruled those out you need to look at the coil and then whatever triggers the spark on the engine.
Gaz
Zedxfarin
PostPosted: 19:06 - 29 Apr 2010    Post subject: Reply with quote
I took the engine cover off today and reatached the kick start. The fly wheel is turning when the kick start gos down. There are 4 wires coming from the windings. 3 of them lead no ware and one leeds to a splitter that joins the Earth, Kill Swich and Igniton coil. All the conection between the wires are simply hand twisted together
Zedxfarin
PostPosted: 19:08 - 29 Apr 2010    Post subject: Reply with quote
Gazdaman wrote:
Replace the HT lead
Gaz
I replaced the coil, risister cap and plug.
Blue_SV650S
PostPosted: 19:28 - 29 Apr 2010    Post subject: Reply with quote
The attached wire should NOT lead to earth (directly).
As a first step, wire that wire straight to the coil terminal. Presuming it now sparks properly, then try starting it up (you will have to knock it into gear and 'stall' the bike to stop it).
If all is well, then you need to wire in a kill switch (or not bother and just stall it to stop it).
Zedxfarin
PostPosted: 19:35 - 29 Apr 2010    Post subject: Reply with quote
Its not sprking just now but i will try that in 15min
Blue_SV650S
PostPosted: 19:47 - 29 Apr 2010    Post subject: Reply with quote
I can see how it might read now, but I meant presuming it sparks AFTER sorting the direct wire Thumbs Up ...
Zedxfarin
PostPosted: 19:52 - 29 Apr 2010    Post subject: Reply with quote
Well i just tried wiring to the ignition coil directly. Sadly no spark i held the cable with my finger and got a small shock when kicking, I DO have a voltage meater but i dont know how to work it. I dried wiring directly to 3 difrent ignition coils i have.
Blue_SV650S
PostPosted: 19:56 - 29 Apr 2010    Post subject: Reply with quote
Can we have a pic of the wires coming from the stator please ... there is a chance the wrong one has been wired up!! Wink
Zedxfarin
here we are:
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00002.jpg
https://i793.photobucket.com/albums/yy214/zedxfarin/DSC00003.jpg
Blue_SV650S
PostPosted: 21:22 - 29 Apr 2010    Post subject: Reply with quote
Ok I have done some googling (trying to find wiring diagram) ... seems it might be a 'points ignition' ... can you see the points?
I bet they are closed up with a tiny gap or lots of corrosion ... hence the dwell angle is too short or it is not earthing out properly! Wink
Oh and have a gander at this .... https://www.yankeetwin.com/motoplat.html
Zedxfarin
PostPosted: 23:25 - 29 Apr 2010    Post subject: Reply with quote
Yes its a point systam. I have a nuther set of windings from a nuther 348 i have. I took it out today and gave it a bit of a clean.
I'm going to:
Take the mageto out.
Change over the windings.
Replace the mageto and wood ruff key.
rewire the new black cable direct to the coil.
is there any dangers in any of that??
I dont wont to brake anything.
Also on the BASIC MOTOPLAT TESTING doc you posted it say the blue wire should run to a capacitor charge {large terminal} and kill switch. Currently it runs no ware will this stop the bike running?
The last post was made 16 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 134.01 Kb
