NS125R-K engine!
V2
PostPosted: 21:36 - 23 Apr 2010    Post subject: NS125R-K engine! Reply with quote
Hello peeps,
I have recently aquired myself an NS125R-K, I got it as a non starter and had a little play but i cannot get it to start, it has fuel, spark, compression (poor mans test), checked reeds ok etc, i havent had the head off yet but this is next on the list of jobs depending on the answer i get here! Anyway! I was wondering if the wealth of knowlege in BCF could tell me if there is any other larger capacity engine that could be fitted into this frame without too much hassle (a bit of hassle is ok!), i dont really want to go down the route of big bore kits but i do fancy a bit more power than the 125 puts out if its at all possible, well you never know until you have asked and i have asked...
PostPosted: 21:39 - 23 Apr 2010    Post subject: Reply with quote
Only engine that I would expect to fit in fairly easily would be an MTX200, and they are pretty rare.
V2
PostPosted: 22:00 - 23 Apr 2010    Post subject: Reply with quote
damn Laughing i just thought it would make a fairly interesting project if i could squeeze a larger two smoke engine in there! thanks Keith!
PostPosted: 22:09 - 23 Apr 2010    Post subject: Reply with quote
Suspect you could squeeze something like a CR250 engine in there (being fairly small), but I expect it would be a pain without a charging system and would probably vibrate.
V2
PostPosted: 22:20 - 23 Apr 2010    Post subject: Reply with quote
looks like its head off time to see if there is any damage to the barrel then! Laughing
boundy
PostPosted: 22:47 - 23 Apr 2010    Post subject: Reply with quote
What about a CRM250 engine? less vibes than a CR lump and about the same size
PostPosted: 22:54 - 23 Apr 2010    Post subject: Reply with quote
Possible, as I would suspect the mounts would be similar, but I would be far from sure and think that being a road engine it is a bit bulkier which might be an issue squeezing it in.
Think the MTX just needs different length spacers for the same mounts (going from vague memory from 20 years ago).
The last post was made 16 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.47 - MySQL Queries: 15 - Page Size: 52.52 Kb
