| Bubbs |
 Bubbs World Chat Champion
| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 08:30 - 25 Apr 2010 Post subject: |
Just lean more.
Ride more, lean more, go faster, you'll really surprise yourself how far over you can go. But get faster and lean more GRADUALLY.
If you decide to barrel into a corner 20mph faster than usual, you'll crash.
From looking at your sig you're a fairly new rider, so it's all about practise, and learning how far you can take it. For a bench mark, on most bikes you can get the pegs to touch the floor in a corner.
And also make sure you're looking down the road at the exit of the corner, if you're concentrating on the corner too much, you'll get target fixation and find yourself in the hedge. Look through the corner and out the other side, and you'll find yourself round and out before you know it.
When you have a bit more experience a trackday would possibly help, then you can really test what the bike can do, in some safer circumstances. And once you've got your knees down, you know what you can throw at the bike.
Gaz |
| Bambam3 |
 Bambam3 Renault 5 Driver
| Gazdaman |
| iooi |
 iooi Super Spammer
| Bubbs |
| Rob W |
 Rob W World Chat Champion
| Rowey |
 Rowey World Chat Champion
| P.addy |
 P.addy Red Rocket
| Ichy |
 Ichy World Chat Champion
| bacon |
 bacon World Chat Champion
| T0MMY |
 T0MMY World Chat Champion
| MarJay |
 MarJay But it's British!
 Posted: 11:39 - 25 Apr 2010 Post subject: Re: cornering technique |
| Bubbs wrote: | Hi all,
I was hoping you guys/girls could post up some technique that you use when cornering. I don't yet have the confidence to get the bike banked over in a turn as much as i'd like. I'm using the counter steer technique consciously while entering the bend but still almost run wide, or not bank enough. Don't know what the bike will allow me to do really, which i feel is taking the potential fun out of my riding experience.
All/any suggestions are welcome?
Thank you in advance. |
I'm not sure motorcycle cornering in one easy lesson is possible tbh.
However:
On the road you want to approach right handers in the left of your lane, and left handers as far right as possible without crossing the white line. You need to pick your speed carefully and make sure that the braking is all done before you reach your turn in point. It doesn't matter if you're slow at this point, its better to go in slow and come out fast than go in slow and come out in a hedge.
Imagine the point on the road where you want to turn in. Now move that point a few centimetres further into the corner. Keep that point in mind as you approach the corner but don't look at it.
As you reach that point with your front tyre, use countersteering to turn in and move your head to look through the corner. When you turn in you need what is known as 'maintenance throttle' which is where the throttle is not shut but you aren't accelerating hard, just accelerating a little. Almost just maintaining your speed but still accelerating. As you reach the apex of the corner you should see the vanishing point of the corner start to move away from you. As this happens you can start to open the throttle progressively and start accelerating as you bring the bike upright.
https://www.bikechatforums.com/files/lefthander.jpg
This crude diagram should give you a vague idea of your road positioning and the difference in turn-in points on a left hander. Most new/inexperienced riders turn in very early which gives you less of a view around the corner. Leaving the turn in a bit later (the green cross) allows you to see more through the corner, it allows you to not have to lean the bike over as far, and it gives you the full width of the road to use.
The red cross is an early turn in point where you have to crank the bike over more, you can't see what is around the corner and you've got to take a much wider line so as to not hit the inside edge of the corner.
The blue cross gives you a rough idea of the apex.
Now, the important thing to remember about my crap diagram is that it isn't to scale, so don't go barreling into a corner and turn in with your front wheel in the hedge.
Your brain will have a place where it feels it should turn in for a corner. In my experience, the ideal turn in point is usually a little bit further into the corner. Try pushing it further by a few CM, and see how your cornering improves. Don't push it too far though, because I don't want to be responsible for any accidents! If you want to really improve you need to do some advanced training really but unfortunately that isn't usually reccomended until you've been riding for six months or so.
Just remember to stay relaxed, keep your arms loose on the bars, keep your head upright while your body is leant over, drop your inner shoulder into the corner as you turn in, and look as far through the corner as you can manage using your pheripheral vision to see the turn in point and the apex.
Phew.
Here's an article I found on vanishing points:
https://www.cvam.info/index.php?page=main.tips_roadcraft_vanishing ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| CaNsA |
 CaNsA Super Spammer
 Posted: 12:54 - 25 Apr 2010 Post subject: |
I watched this a while ago, and found myself using the techniques mentioned in the vid without realising it.
| Quote: |
"My primary objective in this DVD was to communicate to riders that there is a definite technology to riding. The bike wasn't designed by opinions or good advice and riding is the same, there are technical points that need to be understood. That's the message and focus of this film. Once a rider gets the idea there is a technology then and only then can he conquer his fears and uncertainties on cornering and at that point improvement is virtually unlimited." - Keith Code
Essential for all motorcyclists from weekend riders to racers, Twist of the Wrist II brings Keith Code's best selling book vividly to life, demonstrating precision techniques for overcoming barriers to cornering such as rider input, fundamentals on steering, visual skills, braking, body position, throttle control and more.
From canyon roads to track, techniques are fully explored and laid out using multiple camera angles, onboard shots and CG animation in over 105 minutes of spectacular Hi-Def footage.
The best performance upgrade for any rider, Twist of the Wrist II is the latest product from Keith Code, founder of The California Superbike School and trainer of numerous championship winning riders worldwide.
Clicky to torrent download |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| bEN_ |
 bEN_ World Chat Champion
| TUG |
 TUG World Chat Champion
| L4Isoside |
 L4Isoside World Chat Champion
| evoboy |
 evoboy World Chat Champion
 Posted: 21:25 - 25 Apr 2010 Post subject: |
Just loosen up, relax and enjoy the ride.
Leaning the bike over further will come with experience. Have you had the bike long? Getting used to the bike is the first thing and as has been said, basic maintainence so you have confidence in the machine. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| R34lN1nj4 |
 R34lN1nj4 Derestricted Danger
 Posted: 22:14 - 25 Apr 2010 Post subject: |
If it hasn't been mentioned before;
See if one of the lovely peeps from BCF will give you a hand in person. It's all very well taking on the advice, but sometimes if you see it put into pratice it will make it make sense better.
I suggest getting someone to follow you / you follow them and then you will see what you do differently to them.
A lot of cornering and leaning is down to confidence and experience though and that will only come with riding all the time. Get out there as much as possible and see what you feel happy doing.
A lot of the more experienced amongst us only got to where they are by having a scarey moment or ten, and it's only by realizing that you can get away with certain things that you learn more about the bike you are riding and the skill you possess.
...and as Evoboy said...
RELAX
[EDIT] I wont subject BCF to another copy of my KD by numbers picture, cos I can't find it.... [EDIT] |
| Smooth |
 Smooth Could Be A Chat Bot
| hmmmnz |
 hmmmnz Super Spammer
| GSF Jamie 600 |
 GSF Jamie 600 Scooby Slapper
 Posted: 08:19 - 26 Apr 2010 Post subject: |
Trust your tyres that used to be my problem, i just thoughught they wouldn't stick but now i have total confidence in them, they can go suprisingly far without even a slip.
And next time you fear leaning it over to much, think of itlike this, if you lean it over to much you will probarbly low side, which is a pain in the ass and hurts but if you come off the road you'll probarbly highside and fook they hurt lol
Oh and throttle control plays a huge part in it  |
| daz_d_biker |
 daz_d_biker Spanner Monkey
| metalangel |
 metalangel World Chat Champion
 Posted: 13:24 - 01 May 2010 Post subject: |
Just relax, come in slow and go out fast, keep steady throttle through.
LOOK where you want to go, and steer the bike towards it. A bit like 'padlocking' in air combat games, where you keep your gaze fixed on your target and then maneuver your plane towards it. ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
"A faired bike will get you 10x more clunge than a unfaired one." -Marlboro Matt |
The last post was made 16 years, 143 days ago. Instead of replying here, would creating a new thread be more useful? |
