Weird problem...
Damon
PostPosted: 21:04 - 26 Apr 2010    Post subject: Weird problem... Reply with quote
Hi all,
I finally got round to replacing the sump on the R1 today and when I took the downpipes off each of the inside walls of the downpipes look considerably different from one another. One is coked up, two are fairly coked up and one looks really clean. It leads me to believe that the fueling must be way off??
The thing is though is that the bike feels fine to ride, idles with no problems and seems to pull as it should. I am a bit confused.
I took a picture of my exup valve too as you can clearly see the weird pattern. Could it only be running on 3 cylinders?
What do we think? running on 3 cylinders or just running with stupid fueling? or is there nothing wrong at all? How would I go about rectifying the problem?
https://img697.imageshack.us/img697/9724/img0653b.jpg
https://img402.imageshack.us/img402/1032/img0654r.jpg
The clean downpipe is the 3rd one if counting from the left. Karma cookies for all.
Thanks, Damon
PostPosted: 21:16 - 26 Apr 2010    Post subject: Reply with quote
The grey ones are running about right, perhaps a little lean. The black ones are running too rich.
Is this a fuel-injected or carbed bike?
PostPosted: 21:18 - 26 Apr 2010    Post subject: Reply with quote
Just spotted '99 R1 in your sig - I guess it's carbed then?
Strip-down and clean the carbs, set the float heights and balance the throttles.
Damon
PostPosted: 21:28 - 26 Apr 2010    Post subject: Reply with quote
yeah it is carbed. Thanks for the quick reply. Do you think a clean and balance will sort it out? Or is it a case of getting the fueling set up with some dyno time.
PostPosted: 22:07 - 26 Apr 2010    Post subject: Reply with quote
It's no use taking the bike to the dyno without getting it fuelling the same across all cylinders. The dyno sniffer will only tell you the average across the cylinders because it measures after the collector (in the end can). What you have there is fuelling that varies per-cylinder. That's what you have to sort out first.
Balancing is the final step BTW, because it only affects idle. Once the throttle is open any amount it makes no odds.
Damon
PostPosted: 22:16 - 26 Apr 2010    Post subject: Reply with quote
ok thanks, what is the first port of call then for getting the fueling the same on each cylinder?
PostPosted: 22:20 - 26 Apr 2010    Post subject: Reply with quote
You need to clean out the carbs.
Clean the jets, remove and inspect the slides & diaphragms (carefully). Hold them up to the light to inspect for pinholes. Remove and clean the emulsion tubes. Check the tubes and needles for wear. Check the needle heights are all similar. Re-assemble the carbs and set the float heights so they are all the same.
Damon
PostPosted: 22:53 - 26 Apr 2010    Post subject: Reply with quote
ok brilliant, thanks for your help pete Thumbs Up
el_oso
PostPosted: 09:06 - 27 Apr 2010    Post subject: Reply with quote
acquire the Haynes manual. they are good for torque specs and float heights needle size, shim sizes etc etc
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 15 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 61.94 Kb
