Price list:- 2001 ZX7R
killa
Won't Shut Up
PostPosted: 08:53 - 27 Apr 2010    Post subject: Price list:- 2001 ZX7R Reply with quote
Just gonna get some odd bits for the ZX7R
How much should i be paying for the following....?
Spark plugs
Oil
Oil filter
Air filter
Thanks! Thumbs Up
Paxovasa
PostPosted: 08:56 - 27 Apr 2010    Post subject: Reply with quote
Depends on what oil and what type of spark plugs you buy. Thumbs Up
jakeeNZ
PostPosted: 09:50 - 27 Apr 2010    Post subject: Reply with quote
True, however unhelpful for him.
Cheap plugs about $4 USD max each
Cheap Oil approx $25 USD
Cheap filters will be around $50 USD
Hope this gives an indication
However as with paxovasa's comment, it depends on quality and the cost can go up very quickly by buying quality.
I recommend buying quality plugs, filters and oil as this is the first step in prolonging the life of your engine in conjunction with regular routine maitenance.
However, you need to factor in your personal budget as the 'regular' part of routine maitenance is usually the most important. So buy what you can afford to replace at recommended intervals. If you go cheap you will shorten those intervals a bit. Thumbs Up
Yamaha - Best manufacturer of anything - anywhere
Paxovasa
PostPosted: 10:02 - 27 Apr 2010    Post subject: Reply with quote
If you go for iridium plugs then the price will rise significantly.
I use silkolene motorcycle oil synthetic 10w - 40, 4 litres will cost about £30
bacon
PostPosted: 10:49 - 27 Apr 2010    Post subject: Re: Price list:- 2001 ZX7R Reply with quote
Spark plugs
Oil
Oil filter
Air filter
Thanks! Thumbs Up
Oil £20-£30 depending on what you buy
Oil filter £5-£8
There is a deal in HG, £20 for Motul 10w40 semi synth oil and a filter, il be getting this when my next change is due Thumbs Up
Sparks £5 for normal ones, iridium are about £7-8 each i think
Air filter £12 for the element, dont need to replace the metal gauze or plastic part
killa
Won't Shut Up
PostPosted: 11:02 - 27 Apr 2010    Post subject: Reply with quote
Done and done.
I got them pretty cheap from a dealer near me. Thumbs Up
The last post was made 15 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.39 - MySQL Queries: 15 - Page Size: 49.17 Kb
