Clutch fade
panrider_uk
PostPosted: 11:22 - 28 Apr 2010    Post subject: Clutch fade Reply with quote
If I have to use the clutch a lot (stop/start/crawling pace stuff in town) the clutch lever travels further and further before I get any bite.
If the bike is left for a few hours the clutch is back to normal so it seems temperature related.
It also feels normal on my usual daily commute (either dual carriageway or country B roads).
Is it likely I just need the fluid changing or could it be a sign of something more serious?
Thanks
Mark
jakeeNZ
PostPosted: 11:44 - 28 Apr 2010    Post subject: Reply with quote
How long has this been happening, and is it getting progressively worse?
I'd change the hydraulic fluid anyway if you don't know the last time it was done, the symptom should be something that occurs once the fluid heats up and water separates out and compresses. Hence less and less clutch. If it was (unlikely to be) air, there would be a problem all the time.
If that doesnt work there may be some fluid bypass with heavy use, however this would also be occuring more frequently.
When clutch plates are near death they can slip with high use (heat)
before they slip at any use
Could be a major, change the fluid and answer those questions and we'll probably isolate the issue. let us know. Thumbs Up
Yamaha - Best manufacturer of anything - anywhere
panrider_uk
PostPosted: 11:55 - 28 Apr 2010    Post subject: Reply with quote
Been happening for about a year.
I don't do much stop/start town riding so I keep forgetting about it Smile
I'll make sure the fluid's changed at the next service and see how it goes.
Thanks
Mark
jakeeNZ
PostPosted: 21:28 - 28 Apr 2010    Post subject: Reply with quote
I dont mean to be anything other than helpful here mate.
There is a slight chance that if your next service is a wee way off that you might do damage to the clutch when it is happening.
Make it a priority to change that fluid mate.
Its only a simple hydaulic system, compared to a cars brakes anyway.
We could even talk you through it and DOT4 is cheap as chips
TUG
PostPosted: 22:26 - 28 Apr 2010    Post subject: Reply with quote
What colour is your clutch fluid? if its not clear or a light tint of brown then it needs changing, it will of absorbed alot of water and heated up as its in contact with the engine don't forget.
Change that first is my advice.
Haz ER-5, innit!
panrider_uk
PostPosted: 23:31 - 28 Apr 2010    Post subject: Reply with quote
I'll try and get it changed over the weekend.
Thanks
Mark
jakeeNZ
PostPosted: 00:11 - 29 Apr 2010    Post subject: Reply with quote
Ah thats a bit misleading, even downright rubbish.
Point #1:: There is no reason for a good working system to allow in lots of water.
Point #2:: There is no clutch fluid in the engine.
Point #3:: Hydraulics work by using cylinders to actuate levers by hydraulic pressure transferred to a slave cyclinder instead of cables to actuate levers.
So there is no clutch fluid in your engine, just a slave cylinder, which is actuated by fluid.
The fluid may heat up somewhat as a result of heat radiation from the engine, but thats all.
Good one on prioritising the fluid change mate.
Walloper
PostPosted: 00:19 - 29 Apr 2010    Post subject: Reply with quote
And don't go buying a speshal tool from halfrauds to bleed your clutch.
There's probably hardly any flow from the clutch lever master cylinder so it wont open those check valve things on the eze bleeder tubes
£6 for one of them. Get a bit of fish tank air stone plastic tubing (Cheaper than Chips) and use that. The money saved can be put towards a clutch kit.
For the record A vehicle's clutch is designed to last the lifetime of the vehicle and therefore not a serviceable item.
Unless you are one of those thugs with a wee No. plate and a big pipe hooning aroon an aroon. Hard starts and full power acceleration will take years off any clutch.
Or have you been towing the caravan with that Two Wheeled SUV of yours? Razz
TUG
PostPosted: 23:31 - 29 Apr 2010    Post subject: Reply with quote
I'm sorry, but lets say a TL1000 or a nice little VTR1000 like i have, can you tell me what the slave cylinder piston pushes? is it a rod that travels through the engine to the clutch basket? Does the engine get hot at all or is it just magic? Moisture is in the air, and condensation can cause water vapour to be absorbed into the fluid. If the system was sealed in say a brake system, why does the fluid go black with dirt?
Haz ER-5, innit!
TUG
PostPosted: 23:42 - 29 Apr 2010    Post subject: Reply with quote
If your worried that your master cylinder is at fault a simple test can be used, those brake line pliers at halfauds (plastic things so wont damage your rubber brake line, i'm not sure on braided lines though i'm sorry). Squeeze your lever in, and clamp the line, now keep it clamped, release the lever and try and squeeze that lever again, it should be rock solid, there we go, we just eliminated your master cylinder seals.
Haz ER-5, innit!
TUG
PostPosted: 21:18 - 04 May 2010    Post subject: Reply with quote
Any results?
Haz ER-5, innit!
The last post was made 16 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 68.51 Kb
