Gilera Gsm Problems Still :(
michaelqinn
PostPosted: 20:49 - 28 Apr 2010    Post subject: Gilera Gsm Problems Still :( Reply with quote
heyyy
ive got my gilera gsm , had it rather cheap off a good friend of mine anyway , it revs all the way out when not in gear , but then when you put it into first an try to ride it , it potters along fine untill around 6000rpm then it bits a block wall an wont go any futher , i know its not restricted as i rode it when my friend had it an it went like a rocket firing lovley an pulling like a train , then one day i die's n wont start have change PISTON , BARREL , PLUG , HT LEAD , AN MAGNETO , but it was only a cheap second hand magneto so wondering if this could be damaged to stop it riding properly ? new cdi will be fitted this weekend to see if thats the problem
cheeers Thumbs Up
Quinndawg
skatefreak
PostPosted: 22:14 - 28 Apr 2010    Post subject: Reply with quote
I know this is going to sound really rediculous of my but have you stripped and cleaned the carb?
I'm mad about carbs you see...
But certainly think about trying it if you havnt Smile
Best regards
-Jvr
jakeeNZ
PostPosted: 08:23 - 29 Apr 2010    Post subject: Reply with quote
I agree, do this if you have not already.
Sounds like fuel starvation
Try not to run the bike near the range of engine revs that it stops accelerating at (the rpm that is, not speed acceleration). If it is fuel starvation you could do some serious heat related damage to the combustion chamber by keeping it struggling up there.
Yamaha - Best manufacturer of anything - anywhere
prawny1
PostPosted: 15:58 - 29 Apr 2010    Post subject: Reply with quote
clean your exhaust out it may be coked up in and around the silencer / header the ports are only small.
your other posibilities are weak reeds orcrankseals leaking.
The last post was made 15 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 40.17 Kb
