HELP WANTED FOR CARBURETTOR
ozzyd1979
PostPosted: 05:37 - 29 Apr 2010    Post subject: HELP WANTED FOR CARBURETTOR Reply with quote
My carb is playing up on my superbyke powerband 50 as when it starts its ok but after few mins cuts out of fuel but there is and just want to know where i can get new one or what would u check signs of
OZZYD1979
Ichy
PostPosted: 05:42 - 29 Apr 2010    Post subject: Reply with quote
Check the colour of the spark plug.
get ready to catch any fuel that comes out and undo the drain screw at the bottom of the carb, there should be a steady flow of fuel.
ozzyd1979
PostPosted: 05:47 - 29 Apr 2010    Post subject: Reply with quote
there is but cuts out dont know why
OZZYD1979
jakeeNZ
PostPosted: 08:15 - 29 Apr 2010    Post subject: Reply with quote
Do you still have spark when this happens? Check for us, pull out the plugs and ground them out to the head and turn the engine over when you have the issue.
Have just gone through a week long quest to identify a pickup coil as my issue. They can also be known as ignition sensors.
Have heard that when they begin to fail, that they work fine whilst engine is cold, but as soon as it heats up the spark goes. however, pickup coil failure is total and there wont be any misfiring or such forth, it'll just stop working. Eventually it wont even work when cold
Hope this helps, if it is not the case, i'd get in and either get the carb serviced or service it yourself if you know enough
Good Luck with your issue
Yamaha - Best manufacturer of anything - anywhere
cb1rocket
PostPosted: 10:37 - 29 Apr 2010    Post subject: Reply with quote
If this is a 2 stroker, you sure you have 2 stroke oil going in?
jakeeNZ
PostPosted: 10:45 - 29 Apr 2010    Post subject: Reply with quote
Lmao
He wouldn't have a motor left if he even tried that once. I've seen it done when I was quite young and the engine died a quick and very painful death.
Sounds like hes describing this as a repeating problem, and a 2 stroker wouldnt forgive that. He would know by his top end lunching, seems to describe it just dying, not lunching itself.
ozzyd1979
PostPosted: 19:12 - 29 Apr 2010    Post subject: Reply with quote
It does run slightly but as soon as u pull on the revs it will cut out but if left a little longer it will cut out
yeah its two stoke
OZZYD1979
jakeeNZ
PostPosted: 20:09 - 29 Apr 2010    Post subject: Reply with quote
Blocked jets, fuel starvation
Clean out your carb
jakeeNZ
PostPosted: 23:46 - 29 Apr 2010    Post subject: Reply with quote
CHR15 wrote:
leave the petrol cap on the tank open, go for a \careful\ ride, and see if the problem has stopped.
Good one, didnt think that that the tank vent may be blocked.
Should take a lot more to stall than it does if it were the vent though
Ichy
PostPosted: 09:24 - 30 Apr 2010    Post subject: Reply with quote
What do you have to do to restart the bike? How long do you leave it?
The last post was made 15 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 62.6 Kb
