Derestricting Peugeot xps 50cc geared supermoto/moped
Gregga
PostPosted: 21:18 - 01 May 2010    Post subject: Derestricting Peugeot xps 50cc geared supermoto/moped Reply with quote
hey
im 17 and looking to upgrade to a 125 very soon.
however im looking to fully derestric my current Peugeot xps 50cc geared supermoped/moped however im not to sure how to go about doing this.
do i need to upgrade to performance parts or can i just do a few tweaks here and there. it currenly only does 35 down hill.
any advice much welcome
cheers
G Twisted Evil
ian789
PostPosted: 21:34 - 01 May 2010    Post subject: Reply with quote
Drive off the edge of a cliff.
woll
PostPosted: 09:14 - 02 May 2010    Post subject: Reply with quote
Not 100% sure on your exact bike (is it 2 stroke or 4 stroke) but i know the derbi senda has a restrictor in the zorst and the carb. You may find you need to upjet the bike when you do it.
Tom C RX50
PostPosted: 10:27 - 02 May 2010    Post subject: Reply with quote
pretty sure its a minarelli engine in the peugeot like the aprilia? may be wrong but id take off the exhaust and theres usually a washer just spot welded in the expansion chamber which comes out with the beat of a hammer, there may be a restrictor in the carb too, either in the inlet maifold or in the carb itself. failing this the cdi might also be restricted so a full power one of ebay would do the trick
**FOR SALE** Aprilia RX50, full system gianelli exhaust, 70cc MK big bore, MK pro race filter, 20mm Dellorto carb, aftermarket sticker set, small plate, carbon look indicators, new rear tyre, years tax and mot, new chain and sprockets, very fast bike. 1200 ono **FOR SALE**
Gregga
PostPosted: 08:08 - 03 May 2010    Post subject: Reply with quote
Can anyone recomend a good performance exhaust to upgrade to. seen a few around at different prices but all seem to say the same thing..
p.s its a 2 stroke and i do believe its the engin as mentioned above
cheers
Greg
woll
PostPosted: 11:09 - 03 May 2010    Post subject: Reply with quote
IIRC on a 50 it doesn't make much difference on which exhaust you go for power wise that is. But you want one that will last and isn't going to rust easily (like DEP expansion chamber for DT125R) i'd say just read some reviews on them and pick which ever you want
Gregga
PostPosted: 14:27 - 04 May 2010    Post subject: Reply with quote
do i need to fiddle with the jets atall with a new exhaust?
or anyother methods to get the best of the top speed?
cheers
woll
PostPosted: 18:47 - 04 May 2010    Post subject: Reply with quote
You may need to upjet it, i'd put the new zorst on and see how it runs to see if it runs ok and whether it will need the jets changed
Gregga
PostPosted: 20:15 - 04 May 2010    Post subject: Reply with quote
how can i tell if they will need changing Embarassed
Gregga
PostPosted: 17:57 - 13 Jun 2010    Post subject: Reply with quote
anyone know how to tell if it will need to be up jetted? any tell tail signs to look out for?
also performace air intakes and boost bottles, are they worth it? do they make a difference or do the just reuin the bike?
cheers
Greg
TomDavies
PostPosted: 19:10 - 13 Jun 2010    Post subject: Reply with quote
Hi, the general rule is if you change the exhaust you upjet the bike as exhaust gases are escaping quicker. Best thing to do is stick the pipe on (or de-restrict your current one) take it for a spin and see how it runs, you might not need to.
If you want more top speed you could go up a couple of teeth on the front sprocket.
''also performace air intakes and boost bottles, are they worth it? do they make a difference or do the just reuin the bike?''
And no I wouldn't waste your time, just upgrade to a 125 when you can/money permits.
HTH
Tom
450 exc enduro
Lives in a lonely place near Nantwich, Cheshire
dobby
PostPosted: 10:21 - 14 Jun 2010    Post subject: Reply with quote
you will also need to change the gearing on it eg: 11/12t to a 15t front sprocket as if they are the same engine as the they are massivly down geared Twisted Evil
The last post was made 16 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 71.04 Kb
