| Ant132 |
 Ant132 World Chat Champion
 Posted: 16:14 - 03 May 2010 Post subject: Brake bleeding kits |
Hi,
I changed the pads on my bike a few weeks ago due a spongy feeling lever and the fact they were close to the limit so i also cleaned everything up which involved replacing the fluid.
But now, even after new pads the lever still doesnt feel very firm and is quite spongy. So it must be air still in the system?
What brake bleeding kits are the best for this (cheapish though), i found this one on ebay. It says you can pop the tube on, open the bleed nipple and pump away until bled but do they really work?
Link
Cheers, Ant  |
| Itchy |
 Itchy Super Spammer
 Posted: 16:20 - 03 May 2010 Post subject: |
A brake bleedin' kit? Just get thee some clear plastic tube my local motorfactors sells 2 metres for £2.
What you do is pop a ring spanner on the bleed nipple, then put the plastic tube over the end of it. then put the end of the plastic tube in some brake fluid. This prevents back flow of air into the system.
Pump the brake lever a few times at the master cylinder, use a cardboard tube to hold it in, then undo the bolt. Air should come out along with some brake fluid. tighten it up then pump again and repeat. Top up the master cylinder now and again make sure you do not expose the hole to air. The bubbles should become less and less and eventually you'll hear a creaking noise this is the pistons pushing against the pads and most of the air should be out of the system.
You can actually bleed the brakes without a plastic tube at the top if you want I used to do that, but it will take a very long time. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 16:49 - 03 May 2010 Post subject: |
For a bike what Itchy says is the right thing.
For a car etc I would use an "easybleed" kit.
The one that you have a link to is not the best as the second you have an air leak in the pipe you are back to square one.
You can buy Easybleed brake bleeding nipples. but they are twice the price of standard bleed nipples.
Do what Itchy says, get the knack, and from then on it`s the easiest and cheapest way. ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| stirlinggaz |
 stirlinggaz World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
| Zedxfarin |
 Zedxfarin Nova Slayer
| SlimRick |
 SlimRick World Chat Champion
| ms51ves3 |
| chris-red |
| Walloper |
 Walloper Super Spammer
| SlimRick |
| cb1rocket |
 cb1rocket World Chat Champion
| Dazbo666 |
 Dazbo666 World Chat Champion
| Odie |
 Odie World Chat Champion
 Posted: 16:39 - 05 May 2010 Post subject: |
https://www.bikeit.co.uk/tools_product.asp?ID=226
Have one and its brilliant. ____________________ You are so ugly when you were born the doctor said "I?m gonna drop it, if it falls is a rat, if it flies is a bat." |
The last post was made 16 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
