Heated grips
PostPosted: 22:11 - 03 May 2010    Post subject: Heated grips Reply with quote
On the TDM I have Heated grips, they are oxford and they are the ones with the digital box thing that gives you 4 settings
Looks like this
https://www.sportsbikeshop.co.uk/product_images/oxford_original_heated_grips.jpg
Anyway, when you turn them on it stays on for about 2 seconds then turns off, it does this every time any ideas?
Ta
Chris
PostPosted: 22:20 - 03 May 2010    Post subject: Reply with quote
When you turn them on, is the engine running and how long has it been running? Have some similar HG ones on Charlottes Bandit and they will turn themselves off if the battery power isn't sufficient, and that includes within a few minutes of firing up the engine.
PostPosted: 22:43 - 03 May 2010    Post subject: Reply with quote
It was after engine had been on maybe 10 minutes, The battery is strange I do think there may be something up with it.
During the winter, it would struggle to start the bike, sort of Laughing
As soon as you turn the ignition and thumb the starter it would turn a couple of times then die and the ECU will reset but after that it will be fine and turn over happily for ages. If you time it right you can hit the starert let it turn over once, then off and then it will turn over fine. It is as if it needs to wake up for a few seconds before it will work properly.
The thing is I have been riding it day in day out through winter with this problem and with the grips on the majority of the time. I haven't used the grips for about 3 months and the battery problem has disappeared with the warm weather.
The battery is only a year old but I think it may be the issue, I'll see if putting it on charge will sort it.
Walloper
PostPosted: 11:38 - 04 May 2010    Post subject: Reply with quote
May be a poor connection between the battery and main power relay.
Intermittent power may be due to the shock/vibration when you try to start making the connection appear better-er.
Or it's the main power relay its self.
neatbik
PostPosted: 11:52 - 04 May 2010    Post subject: Reply with quote
First off check the voltage accross the battery Thumbs Up
The last post was made 16 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.08 - MySQL Queries: 13 - Page Size: 44.99 Kb
