ice cream gear box!
shredtheibane...
PostPosted: 22:34 - 03 May 2010    Post subject: ice cream gear box! Reply with quote
Hey people!
Right, fathers just brought a 1989 TZR 125 for £225 (£300 but it died on the way home so was refunded £75) and i have a few questions.
Firstly,
Does this look like the water and oil have mixed?
https://i44.tinypic.com/2usz86x.jpg
The only thing i can think of is water pump seal..
Secondly, the idle is really bad, i have turned the pilot out 1 3/4 turns and when i set the throttle stop it just simply doesn't work. One minute its to low then turn it a fraction and its singing at 5k. Also when you pull the choke out it goes up to around 3 and instantly stalls... I'm guessing its running too lean, i'm going to strip the carb any ways but will it be the float level? or a dirty jet?
Any input is welcome!
Thanks,
Ryan
Blue_SV650S
PostPosted: 22:38 - 03 May 2010    Post subject: Reply with quote
With those symptoms, I'd be suspecting a head gasket failure!
PostPosted: 22:44 - 03 May 2010    Post subject: Reply with quote
Water pump seal would be my first guess as well.
Not likely to be head gasket being a 2 stroke (would need the main bearing seals to have gone as well).
shredtheibane...
PostPosted: 19:01 - 04 May 2010    Post subject: Re: ice cream gear box! Reply with quote
Thanks for your comments,
Okay, so i've replaced the seal and am cleaning through now.
does anyone know why the idle is so bad?
Ryan
shredtheibane...
PostPosted: 21:04 - 04 May 2010    Post subject: Re: ice cream gear box! Reply with quote
BLUEX5 wrote:
Ryan
Pilot jet blocked maybe??????
i will certainly take a look!
Thanks
The last post was made 16 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 48.95 Kb
