Hornet starting after a long stand
phil.fuse
PostPosted: 23:10 - 03 May 2010    Post subject: Hornet starting after a long stand Reply with quote
Hi there,
my Honda Hornet (98 model) has been stood for 5 months now and i can't get it to run.
Battery seems fine (tho charged it anyway) as i can start it on full choke (which is usual) and it starts but sounds really rough and after a few minutes it cuts out and won't turn over again for some time.
any advice would be great else i'm going to have to get it picked up and taken to a garage Sad
alun111
PostPosted: 03:39 - 04 May 2010    Post subject: Reply with quote
I'd give the spark plugs a clean and maybe resort to cleaning the carbs. Start with spark plugs though - If cleaning doesn't sort it out then purchase and fit some new ones.
el_oso
PostPosted: 10:11 - 04 May 2010    Post subject: Reply with quote
check your airbox for crap (and mice)
Duke 390
Car: Jeep Wrangler 4.0L
Davo
Davo To The Rescue!
PostPosted: 10:13 - 04 May 2010    Post subject: Reply with quote
In addition to the above
I'd be tempted to at least drain the float bowls, then chuck some fresh petrol in as well.
Paxovasa
PostPosted: 10:18 - 04 May 2010    Post subject: Reply with quote
I would chuck some fresh fuel in the tank and maybe some redex Thumbs Up
Edit: I do mean do the above after cleaning the plugs or replacing them with new ones Thumbs Up
Cigaro
PostPosted: 10:45 - 04 May 2010    Post subject: Reply with quote
I would still suspect the battery even though you said you have "charged it just to make sure".
Could always try jump-starting from a car. Worth doing before you start messing with other stuff.
phil.fuse
PostPosted: 20:09 - 04 May 2010    Post subject: Reply with quote
thanks all...
re the battery - it does start - it just dies after a few mins of running rough then some nasty chugging - and it did bump down the very slight hill i live on (tho getting it back up was a nightmare)...
i've just drained the tank with the plan to stick some new petrol in once i've disposed of the old...
air box - check...
will look at the plugs whilst i've got the tank off.
took a lil while to get it off and turned out the tube was slightly corroded at the top so it split the last 3/4 inch bah...
mention of cleaning the carbs as well - i'm a newb on maintenance - i have a haynes manual but is this sumit i'm likely to screw up if i try it myself?
The last post was made 16 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 50.27 Kb
