tzr seizing!!! then starting!!!
cloric_tzr
PostPosted: 14:01 - 04 May 2010    Post subject: tzr seizing!!! then starting!!! Reply with quote
ok yesterday i fiddled with my power valve because it turns out the previous owner had 'restricted' her by turning her to the wrong position.
so i sorted that played with the tunning and i was very suprised to see the diffrence it made.
then at about half five last nite (3 hours after id done it) i was ridding home doing bout 70 when all of a sudden the bike locked up and slide sideways i luckely grabed the clutch in and rolled to a stop (engine not running so she defintly snagged somthing.)
so there i was standing at the side of the road, i decided to gently push the kick over to she how bad it was. to my suprise no resistance at all so i gently turned her over at least 10 times to she if i could feel any tight spots or clanging rattling etc. nothing sweet as a nut sooo being 5 miles from home i started her again 1st kick then gingerly rode her home dint go above 35 the entire way no problems at all no knocking pinking rattleing clunking anything. sooo wtf happened. have i not tightend the valve properly and the piston has jammed against it an i was lucky enough to grab the clutch before any damage was done or is this going to become a regular problem now. i took the exaust off and the valve didnt seem to have moved. any ideas? rick
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
tutton
PostPosted: 14:12 - 04 May 2010    Post subject: Reply with quote
Have you checked the powervalve blade hasnt hit the piston?
sounds weird the blade wasnt in the right position then when it is you get that. either way its likely its fucked now, even if its nipped up itll now be loosing compression, so get your wonga out for a top end replacement soon Laughing
richbike
PostPosted: 15:23 - 04 May 2010    Post subject: Reply with quote
TZR rotary YPVS shouldnt hit the piston unless its properly humped in which case it would be a write-off. Might be de-restricting it has uncovered a problem with 2-stroke supply (or general knackeredness) causing it to nip up at higher revs.
check the plug for running lean and make sure the autolube system is OK
cloric_tzr
PostPosted: 16:34 - 04 May 2010    Post subject: Reply with quote
i sorted the auto lube a few weeks ago i did suspect by de restricting it its showing the tru ware of the bike i mean its 21 yr old im the 20th owner an ive no idea whether or when its had a re build in its life. although i did check out the piston through exaust port no black or visible scouring but then again i only saw a small portion of piston. rebuild time me thinks. only take me a day i recon. other ideas welcom tho. . .
richbike
PostPosted: 16:38 - 04 May 2010    Post subject: Reply with quote
was it running hot when it seized?
cloric_tzr
PostPosted: 17:02 - 04 May 2010    Post subject: Reply with quote
no not at all that was 1st thing i looked at not even half way usual runnin temp
oldbiker
PostPosted: 18:36 - 04 May 2010    Post subject: Reply with quote
I guess its a 2ma\1kt or reverse cylinder 3ma.
visit the tzr250 forum and quizz the geeks.
But I would get the barrels off and check it out.
Other things to look for are a lack of coolent (is the pump working),
air locks in the oil line (mine are clear plastic Idea ),
have the rings been in for a long time? they go in with about a 15thou end gap and it`s good practice to change them every 5000 miles or so on a tzr (use genuine or a decent jap set such at RIK.
But its worth getting a manual on line
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
cagiva gezzer
PostPosted: 18:58 - 04 May 2010    Post subject: Reply with quote
You didn't up the jetting when you de-restricted it so it ran lean and seized. As above, rebuild time for mucho money.
cloric_tzr
PostPosted: 19:17 - 04 May 2010    Post subject: Reply with quote
BLUEX5 wrote:
No chance of it being a TZR125 then? Rolling Eyes
yea my bad its a 2rk 1988 125 sorry 4 any confusion
cloric_tzr
PostPosted: 19:21 - 04 May 2010    Post subject: Reply with quote
i say i deristricted it i just turned the powervalve to where it specified in the haynes manual and under instruction by a qualified mechanic.i think she just a old lady needs some tlc im just looking at new parts now
so far ive decided:-
makita piston
full gasket set
crank seal
crank bearings
im just gna take the head off and check piston and state of the barrel. may need a re-bore Mad
anything im missing? thats a full piston kit not just piston
PostPosted: 20:56 - 04 May 2010    Post subject: Reply with quote
Don't think there were jetting changes needed on the TZR125 when derestricted. The Yamaha manual doesn't specify different jetting for the UK restricted bikes.
Agree with Richbike that the piston shouldn't be able to touch the power valve
Personally I would suspect that either the oil pump was wrong adjusted, the oil supply was interupted or there is an air leak.
Chances are pretty high that the piston is wrecked and that it needs a rebore.
cloric_tzr
PostPosted: 23:05 - 04 May 2010    Post subject: Reply with quote
yea ive started stripping her down just ordered a full gasket set off fleabay. ill order a new piston set tomorrow when ive got the barrel off to see if its been re-bored or if i need to bore it again. my mates going to port an polish it at work 4 me free of charge which is cool.
completely my fault ive been riding bikes since i was 11 im now 22 an made a novice error of letting my 2 stroke oil deplete completly hence frying my engine Embarassed Rolling Eyes wont be doing that again. the piston was clearing the valve fine. cheers for your help chaps + kickstart always sound advice. ill try to upload some photos tomoz of the damage. rick
PostPosted: 13:15 - 05 May 2010    Post subject: Reply with quote
Don't order the piston until you know what size you need (which will depend on whether it has been rebored and how much damage there is).
Does he really know what he is doing? It would be very easy to lose power from porting, and polishing the ports is unlikely to give you anything at all.
cloric_tzr
PostPosted: 20:43 - 05 May 2010    Post subject: Reply with quote
are normal vaniers acurate enough to mesure my piston? im getting a reading of about 56.4mm which is the standard size for my bike im just nervous of ordering a new piston going on tht mesurement because i no digital 1nz are more precise. i cant afford to order the wrong piston as i need the bike for work. im getting a exact mesurment of 56.4mm fom the cylinder and a messurment of 55.9 from the piston (i think there abouts) so im guessing that i need a standard piston. will oversized piston have the size stamped on the top?
The last post was made 16 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 91.91 Kb
