Drilling a bolt out
t121anf
PostPosted: 15:07 - 04 May 2010    Post subject: Drilling a bolt out Reply with quote
anyone offer some advice on this.
mate has a car engine with a snapped engine bolt which needs to be removed so he can refit the engine.
the bolt is in an easy position to drill out but wont come out using an easy out, it even has one snapped in it.
what advice can you offer?
this a pic of said bolt
https://i26.photobucket.com/albums/c138/pugboy360/013.jpg
t121anf
PostPosted: 16:44 - 04 May 2010    Post subject: Reply with quote
not sure tbh, good call on the left hand drill bits will tell him
MaybeGuy
PostPosted: 16:50 - 04 May 2010    Post subject: Reply with quote
good luck drilling it with an easy out stuck in it. they're useless unless its on an already loose bolt.
heat it. its got loctite on it.
doggone
PostPosted: 17:23 - 04 May 2010    Post subject: Reply with quote
If you can get a drill in it, sometimes you can whack in an old screwdriver of random chunk of metal.
The vibrations and heating will have helped loosen it hopefully.
If you can heat it with blowtorch or something that will help too.
If that won't work as above bigger drills until something gives way and you can wangle out the remains.
stirlinggaz
PostPosted: 18:23 - 04 May 2010    Post subject: Reply with quote
cobalt drills ftw!
best investment i have made in a while.
got a load of de-walt 2,3 & 5mm cobalt bits for a tenner.
i'd tried hss & failed.
tried titanium & again failed.
then snapped one of those bloody useless extractors, it got a couple of mm in & snapped! leaving the tip embedded in the bolt.
cobalt drill cut through it like butter.(just do it very slowly & use something to keep it cool, i just used freezer spray/lube as it was all i had)
worked my way through the different sizes of drills & then used my tap & die set to cut new threads. (i knew i would find a use for the tap n die set i bought years ago,lol)
felt quite pleased with myself.
cheers,
GAZ
t121anf
PostPosted: 10:18 - 06 May 2010    Post subject: Reply with quote
cheers guys, he has a link to this thread so i'm hoping he's reading it
stirlinggaz
PostPosted: 12:12 - 06 May 2010    Post subject: Reply with quote
im just about to do the same thing, coincidence?
my mate has sheared off the top of a bolt, that holds the exhaust manifold on.
the stub is flush with the cylinder.
i've had to strip the bloody thing down, drain the coolant, remove the radiator etc, just because of his cack handedness.
wish me luck,
now where did i leave those coabalt drills........
cheers,
GAZ
Walloper
PostPosted: 13:07 - 06 May 2010    Post subject: Reply with quote
Hardest bit next to a Diamond tip is the Carbide Plates welded into masonry bits.
Grind a cutting edge onto the tip and Hey Presto... You can drill through anything.
They are not proper twist drills as they do not have much of guide from the sides due to the extra clearances for masonry so accuracy is not perfect but with a bit of care they will beat any cobalt bit.
Lots of coolant.
MarkJ
PostPosted: 13:17 - 06 May 2010    Post subject: Reply with quote
Cut a slot into it and use an impact driver with a flat head tip?
t121anf
PostPosted: 16:23 - 06 May 2010    Post subject: Reply with quote
thats not a bad idea if there is enough meat to cut into before drilling
stirlinggaz
PostPosted: 16:27 - 06 May 2010    Post subject: Reply with quote
pfffftttt,
cobalt drill. 3mm. went straight through the 4 inch bolt stub.
slow speed drill & a bit of coolant.
just to tap some new threads now.
imo, cobalt is hard enough for steel (D200 for stainless steel)
though if you snap a cobalt bit, next logical step up is a carbide bit.
never had to use one yet. (touch wood)
cheers,
GAZ
Ed Case
PostPosted: 21:53 - 06 May 2010    Post subject: Reply with quote
The only place for "Easyouts" is in the dustbin, the damn' things make a difficult problem into a nearly impossible one. Get shot of 'em.
PostPosted: 22:25 - 06 May 2010    Post subject: Reply with quote
Ifit's got a broken easy-out stuck in it you'll have to use a carbide drill to make a hole.
Looks like it has a small amount protruding. If it has, what I would do is take the next size nut, a normal mild steel one, and put that over the broken bit then give it a good squirt with a mig welder. You should be able to remove it then.
Raffles
PostPosted: 23:10 - 07 May 2010    Post subject: Reply with quote
Whilst perusing the forum last night I came across this thread and decided to have a little read.
I have previously tried to drill out broken studs on many occasions with varying degrees of success ranging from dismal failure to outright disaster! I have always used HSS drill bits and was not aware of cobalt drill bits untill reading stirlingaz's post.
Today I snapped a bolt whilst removing the stator plate on my Sherco. I went out and purchased some suitably sized cobalt drill bits and the resulting outcome was an outstanding success. Cobalt drill bits and stirlingaz FTW Thumbs Up
The last post was made 16 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.34 - MySQL Queries: 13 - Page Size: 80.87 Kb
