Recommend me some instand gasket
Robby
Dirty Old Man
PostPosted: 21:58 - 04 May 2010    Post subject: Recommend me some instand gasket Reply with quote
The rocker cover on a CB250RS doesn't have a gasket, just some goo. They're notorious for leaking. There's a bit of pressure behind them, its an air cooled engine, and at one point the sealant is about an inch from the two exhaust pipes.
Hylomar blue has proved useless, it's no good with heat or oil. What have you used?
MaybeGuy
PostPosted: 22:03 - 04 May 2010    Post subject: Reply with quote
hylomar on its own shouldnt really be used for anything imo.
just use silicone sealant
Ichy
PostPosted: 22:07 - 04 May 2010    Post subject: Reply with quote
I use permatex 1372 sealant, works really well. There are a few similar types.
Dazbo666
PostPosted: 22:15 - 04 May 2010    Post subject: Reply with quote
I use Loctite Instant Gasket Thumbs Up
https://www.binbin.net/photos/loctite/loc/loctite-instant-gasket-40ml.jpg
Word of the day : DILLIGAF
evoboy
PostPosted: 23:43 - 04 May 2010    Post subject: Reply with quote
Ive used a Black Permatex Instant Gasket to good effect.
Infact its currently sealing the rocker covers on my pre divvy XJ Thumbs Up
APT Motorcycles
PostPosted: 00:41 - 05 May 2010    Post subject: Reply with quote
Permabond A136 thixotropic liquid gasket.
It's a thickish liquid which turns into a solid when compressed. You can run a bead of it on or spread it out with a fingertip then wipe the excess away from the inside edge of the mating surface with a cloth. Doesn't set until assembled. Wipes off with a cloth after dismantling.
Awesome stuff and smells like red liquorice.
27cows
PostPosted: 07:53 - 05 May 2010    Post subject: Reply with quote
Could you not just get a rocker cover gasket?
Robby
Dirty Old Man
PostPosted: 09:19 - 05 May 2010    Post subject: Reply with quote
Such a thing doesn't exist for the bike, it's meant to use goo.
Thanks guys, it seems that the problem is just that I've been using blue hylomar which isn't suitable for the job. Have ordered one of the recommended things.
Of course, if it doesn't work, I'll hold you responsible.
DrDonnyBrago
PostPosted: 14:03 - 05 May 2010    Post subject: Reply with quote
Seemed pointless starting a new thread for this so here is my hijack:
What sealant to use in here (red box in pic)? It is in addition to a rubber wedge that fills this cutout. The bike is a 2001 CBR600F.
PostPosted: 15:32 - 05 May 2010    Post subject: Reply with quote
The official answer would be "Pro-honda liquid gasket compound" at £12 per tube. Honda part number: 08CRAHLG120G.
In reality, pretty much any silicone RTV type instant gasket will be up to the job.
jimspeed
PostPosted: 15:35 - 05 May 2010    Post subject: Reply with quote
On the vw engines i do at work we use loctite 518 which is like a red paste that only sets once it has no air, very similar to the permabond that stinkwheel recommended just prob more expensive.
its made to join 2 metal surfaces together to be oil and air tight
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
PostPosted: 17:26 - 05 May 2010    Post subject: Reply with quote
Most of the above but use a paintbrush to apply it so that you keep the squeeze-out to a minimum. You want one of them small brushes with quite stiff bristles about 3/4" long.
Walloper
PostPosted: 17:41 - 05 May 2010    Post subject: Reply with quote
And nada Grease or oil on the surfaces to be bonded. NADA!
The last post was made 16 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.98 - MySQL Queries: 15 - Page Size: 77.25 Kb
