Gear problems
EUMP
PostPosted: 15:36 - 05 May 2010    Post subject: Gear problems Reply with quote
Right, this happened a while ago and stopped for a while, now its back and worse.
When it first gear coming to stop it wont shift to neutral and even finds it hard moving, so i have to stall it then try, now however I can't even do that, i have to put the engine switch off and reach over with my arm to manually shift which is now not possible.
When moving off, changing gear to second, it will go into this gear then fall back into neutral causing it to over-rev, this is happening alot with the gears its not hitting into the correct gear and slips back - even with alot more kick to the lever.
EDIT: At first i thought maybe the chain was dry or something but its perfectly lubed up, lever is sort of loose and has been tightend but problem still exists.
C.B.T - Expired
MOD1 04/08/10
MOD2 10/08/10
stirlinggaz
PostPosted: 15:41 - 05 May 2010    Post subject: Reply with quote
hi,
what bike is it?
tried an oil change?
tried adlusting the clutch cable?
sometimes its the basics!
cheers,
GAZ
EUMP
PostPosted: 17:19 - 05 May 2010    Post subject: Reply with quote
hey, messed about with the clutch and re-adjusted it, all working fine now, for now anyway Laughing
C.B.T - Expired
MOD1 04/08/10
MOD2 10/08/10
The last post was made 16 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 34.98 Kb
