Bike cutting out when coming to a stop
everyreasonto
PostPosted: 21:08 - 05 May 2010    Post subject: Bike cutting out when coming to a stop Reply with quote
Just got my zxr400 back on the road after some cam-chain tensioner issues but now i'm having a different problem. When I slow to a stop, the bike cuts out.
At first I though it was something I was doing wrong but I couldn't consistently replicate it. The only way I found to prevent it, is when it is coming down the revs whilst slowing down, at about 2k if I quickly blip the throttle, it usually comes down to idle just fine.
The last thing that got done to the bike was getting the carbs balanced. When it happens I can usually start it back up straight away if I am still rolling.
It might be worth mentioning that sometimes it doesn't always start straight away in the morning, could this all be caused by a duff battery?
It's a bit embarrassing overtaking a car, only to have it overtake me again at the next roundabout as I am desperately trying to get it started again Embarassed
Help Crying or Very sad
richbike
PostPosted: 01:10 - 06 May 2010    Post subject: Reply with quote
sounds like they unbalanced the carbs.
You tried upping the tickover?
if it aint broke, fix it 'till it is...
Alexio
PostPosted: 02:27 - 06 May 2010    Post subject: Reply with quote
Uping the tickover speed might "solve" it but not properly. If the battery was duff it is possible that once the revs come down the alternator isn't producing as much electricity and so it cuts out on a sudden weaker spark, although that would mean that it wouldn't be idling at all I think.
Carbs not being balanced properly might well be the cause but if just one of your cylinders didn't manage to fire, or fire "strongly" enough I would assume that the other one firing would have enough momentum to get it going again (seeming as you claim it is capable of idling) but I really wouldn't know and I suppose that varies from engine to engine.
I can't even think logically why an unbalanced carb would affect the engine dying from coming down from high revs if it's still capable of idling though.
The engine is obviously reacting to spinning down and hence spinning faster than the amount of petrol given to it that it would need to ordinarily go at that speed. A faster spinning engine though surely means more energy to compress what ever fuel is going in to it and therefore I really don't know why this would have an effect either. All I know is that I'm blubbering on like a tired idiot who needs to switch off his laptop already and sleep. I'll be interested to know what's really wrong Thumbs Up
mr rip
PostPosted: 08:50 - 06 May 2010    Post subject: Reply with quote
I've had a similar problem with a couple of my bikes & it turned out to be the mixture too rich at the air screw
if I had to guess I would say start looking there
never criticise a man until you've walked a mile in his shoes, then when the muck hits the fan you'll be a mile away & you'll have his shoes
Paxovasa
PostPosted: 09:26 - 06 May 2010    Post subject: Reply with quote
Does it do it when the engine is still relativly cold or when the engine has warmed up?
PostPosted: 09:33 - 06 May 2010    Post subject: Reply with quote
It could be a badly adjusted clutch too...
mr rip
PostPosted: 09:36 - 06 May 2010    Post subject: Reply with quote
good point,
mine wasn't to bad if I had just been pottering round town, but it got worse if I had been hooning it a bit
everyreasonto
PostPosted: 19:34 - 06 May 2010    Post subject: Reply with quote
This stuck out to me because the bike is restricted, could this be the reason?
It tends to do it more if I am coming down from a high speed. The bike is always warmed up for 5-10 minutes before I set off so I don't think this would be the problem.
I've heard people mention the side stand killswitch, but surely if this was the case I wouldn't be able to set off in the first place?
Oh and I forgot to add, when I was riding it yesteday, I was slowing down, doing about 10mph, pulled clutch in, and it cut out.
There is a gap of 8 years, 3 days between these two posts...
Nomasd1019
PostPosted: 06:36 - 08 May 2018    Post subject: TRIUMPH 675 Cuts out Reply with quote
I just bought a 675 Triple, and every time I come to a stop it cuts out.
I'm just wondering if it could be the TPS Sensor as he says it is?
Any advice would be awesome.
Teflon-Mike
tl;dr
PostPosted: 06:43 - 08 May 2018    Post subject: Reply with quote
Holey thread necromany!
This is an eight year old thread, about a bike with carbs in which I see no mention of a Throttle-Possition-Sensor for a fuel injected bike, the ZXR400 isn't!
Did you not think that a new thread would have been appropriate to your problem?
The last post was made 7 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 67.04 Kb
