125cc Pit Bike Top End Stuck
Zedxfarin
PostPosted: 18:17 - 06 May 2010    Post subject: 125cc Pit Bike Top End Stuck Reply with quote
I have tryed everything to get the top end of my friends pit bike. I placed a bit of wood on it and hit it wi the hammor with no luck. Is there any other tricks i can try to get it removed. I might add that it will buge a wee bit here and there but it will "Pull" itselft back in place.
Montesa Cota 350cc, Yamaha DTr 125cc, Yamaha Timberwolf 250cc, Yamaha YZ 250cc, Kawaski kmx 125cc, Kawaski kmx 200cc, Yamaha TY80cc, 175cc Chinese Dirt Bike, Chinese Wanyge 125cc, Mini & Midi Moto 50cc - What i have owned.
MaybeGuy
PostPosted: 18:19 - 06 May 2010    Post subject: Reply with quote
take all the bolts out
Zedxfarin
PostPosted: 18:22 - 06 May 2010    Post subject: Reply with quote
Hmm i realy have????
MaybeGuy
PostPosted: 18:28 - 06 May 2010    Post subject: Reply with quote
ohc or pushrod?
Zedxfarin
PostPosted: 18:53 - 06 May 2010    Post subject: Reply with quote
I dont know what that is so its proble wht the problem is lol
MaybeGuy This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Zedxfarin This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
The Artist
PostPosted: 19:17 - 06 May 2010    Post subject: Reply with quote
TBH if you are asking how to remove a top end on here, you shouldn't be doing it for a mate.
Just make sure every bolt is out, piston moves freely etc
Go through everything that attaches the top end to the bottom end and make sure everything is undone.
PostPosted: 19:37 - 06 May 2010    Post subject: Reply with quote
Zedxfarin wrote:
your a bit harsh i just need a bit of advice.
Actually, he probably did give you the proper advice. Remove the CCT (camchain tensioner) and release the camchain, remove the cam. If you have already done all of this then it's probably springing on the head gasket, which is probably stuck on the dowels.
Zedxfarin
PostPosted: 20:47 - 06 May 2010    Post subject: Reply with quote
ok so its got a cam chain holding it in. THX "I think" Mr. Green
Robby
Dirty Old Man
PostPosted: 21:43 - 06 May 2010    Post subject: Reply with quote
It will if its OHC. Not if its pushrod. If you have no idea what you're doing, and you clearly don't, leave it alone until you get a manual and learn what you're doing.
binge
Emo Kiddy
PostPosted: 23:34 - 06 May 2010    Post subject: Reply with quote
They run a cam chain up the left hand side of the engine.
Underside of the crank cases. There is a 14mm bolt. Unbolt this and the CCT will be released.
Top of the engine, On the right hand side of the cylinder head. There will be an 8mm or maybe 10mm hex bolt in the middle.
Undo this, It's a long bolt which passes through the head, And holds the Cam sprocket cover in place.
The cam sprocket cover will fall off in your hand pretty much. And then you can go about releasing the Cam Chain.
Best way to do this, Is to unbolt the sprocket it's self. Then wrap a small cable tie through the middle of the sprocket, And over the top of the chain. So you hold the teeth in place on the chain, and dont knock it out of time.
The sprocket only bolts back on one way, So providing you keep the chain and sprocket connected, You wont need to set the timing up again.
Hope this helps.
Ben
The last post was made 16 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 74.56 Kb
