KE125 1981 CHARGING SYSTEM HELP
MR BLUE SKY
PostPosted: 07:07 - 07 May 2010    Post subject: KE125 1981 CHARGING SYSTEM HELP Reply with quote
can someone please assist me with this problem, i cant work it out from the wiring diagram.
It concerns the 2 wires which come from the magneto to the rectifier (1 pink and 1 green). it has a 2 prong rectifier so one need to attach one ( currently the pink) to the rectifier and the other prong must attach direct to the the battery for charging purposes.
which leave me with the green wire? what does this attach to? currently it not attached to anything.
i have tested the battery to see if im charging it whilst running , buts only slightly high volts than when not running, the manual states it should be around 8.5 from the rectifier pre conversion. but its only just around 6 v only a faction higher thn when not running the engine.
so i need to fing out where this green wire attaches to and how it all links together so it charges the battery
can any please help
thanks
molex
PostPosted: 16:38 - 07 May 2010    Post subject: Reply with quote
KE125 81 wiring see attachment
MR BLUE SKY
PostPosted: 18:31 - 07 May 2010    Post subject: Reply with quote
Thanks
do you have a diagram for the 1981 A7 as this is a different model and it has totally different wiring and a different rectifier
thanks
molex
PostPosted: 09:30 - 08 May 2010    Post subject: Reply with quote
KE125 A7 should be year 1980
So here you are attachment
MR BLUE SKY
PostPosted: 10:11 - 08 May 2010    Post subject: Reply with quote
thanks for the diagram, does anyone know about the charging system on this bike? as you can se the 2 wires from the magneto go to the only 2 prongs on the rectifer? but how is this contected to the battery for charging purposes?
The last post was made 16 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 42.38 Kb
