Thread pitch
PostPosted: 21:35 - 07 May 2010    Post subject: Thread pitch Reply with quote
How can you tell what pitch a thread is 1/1.25? What is most commonly used on bike fairings?
PostPosted: 21:43 - 07 May 2010    Post subject: Reply with quote
I've never seen a fairing bolt that wasn't standard pitch.
So that's M5 x 0.8 or M6 x 1.0
PostPosted: 21:46 - 07 May 2010    Post subject: Reply with quote
Not sure there is a choice between metric coarse or fine for small bolts like those used on fairings.
List of the threads and pitches are here:-
https://en.wikipedia.org/wiki/ISO_metric_screw_thread
PostPosted: 21:52 - 07 May 2010    Post subject: Reply with quote
I'm 95% sure it is M6 x 1 thanks guys.
PostPosted: 22:17 - 07 May 2010    Post subject: Reply with quote
https://img.photobucket.com/albums/v295/chris-red/53dd23ea.jpg
It is 12mm on the head 6mm on the shaft and 19mm long, it is m6 x 1.0? I'm guessing yes?
PostPosted: 22:31 - 07 May 2010    Post subject: Reply with quote
Yep, M6x1. Is that an alloy bolt anodised black?
PostPosted: 22:36 - 07 May 2010    Post subject: Reply with quote
I'm not sure, it holds on the Missle launchers I'm replacing them because the heads are slighly Orangy with rust and stand out as there is not a spot of rust anywhere else on the bike. Am I right in thinking ally shouldn't rust? They are also Torx heads which are a pain.
stirlinggaz
PostPosted: 22:44 - 07 May 2010    Post subject: Reply with quote
swap 'em for these https://cgi.ebay.co.uk/m6-x-10-stainless-button-head-screw-allen-bolts-x-10-/260562616695?cmd=ViewItem&pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item3caabe0177
i've bought stuff frome here recently.
cheers,
GAZ
PostPosted: 23:33 - 07 May 2010    Post subject: Reply with quote
Take a set of calipers and measure from peak to peak on two adjacent threads and you'll be measuring the pitch.
No they are too short and are Silver they need to be Black or they will not look right. Also the head looks too big.
prawny1
PostPosted: 01:01 - 08 May 2010    Post subject: Reply with quote
You need a thread pitch guage they are only a few £, No more guessing.
hellkat wrote:
stirlinggaz
PostPosted: 11:19 - 08 May 2010    Post subject: Reply with quote
hi,
i thought you said they were M6 x 1.00, the ones i linked to are 10mm long. (1cm)
they also do other lengths though.......
& they are standard button heads.
i thought you had a problem with rust, you wouldnt have that problem with s/s.
im guessing the cases which they bolt into are black then.?
guess you will have to get anodised black then?
as black carbon steel will rust also.....
definately get a thread pitch guage, i got one in a cheap tap & die set i bought years ago & has been invaluable.
looks like this https://cgi.ebay.co.uk/METRIC-WHITWORTH-THREAD-GAUGE-IDENTIFY-MOST-THREADS-/380225989240?cmd=ViewItem&pt=UK_Hand_Tools_Equipment&hash=item58873c2a78
you could try something like this https://cgi.ebay.co.uk/M6-x-12-Button-Head-Screw-Black-High-Tensile-Bolt-x20PK-/300422776194?cmd=ViewItem&pt=UK_DIY_Material_Nails_Fixing_MJ&hash=item45f297c582
or do what others do, & take the old bolts to any hardware store & get them to match them?
cheers,
GAZ
virus
PostPosted: 11:27 - 08 May 2010    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
M6x1.00 designates the diameter and pitch of the threads, not the length of the bolts.
John
own: 81 xs1100g...
stirlinggaz
PostPosted: 20:14 - 08 May 2010    Post subject: Reply with quote
that'll teach me to skim through posts, oops
i really should have known better, seeing as i spent the day before drilling out sheared off manifold bolts & tapping new threads.
i thought he meant M6, standard pitch, 10mm long,
i'll get my coat.
cheers,
GAZ
27cows
PostPosted: 21:33 - 08 May 2010    Post subject: Reply with quote
The Japs seem to have a fetish for fine pitch fasteners.
PostPosted: 23:13 - 08 May 2010    Post subject: Reply with quote
Fine pitch threads are stronger and you get more clamping force for the tightening torque. Also, because the minor diameter of the thread is larger on a fine thread the bolt is less likely to snap.
Nufkamp
PostPosted: 08:13 - 09 May 2010    Post subject: Reply with quote
That depends upon the material the female thread is in.
As seen on Google Street View https://tinyurl.com/yfdvojc
27cows
PostPosted: 09:45 - 09 May 2010    Post subject: Reply with quote
They also tend to be more prone to seizing in.
PostPosted: 10:05 - 09 May 2010    Post subject: Reply with quote
I'm not sure I can agree with that. I've tried and I can't think of a time when I last had a seized fine thread bolt on a bike. Of course, they tend to be used in areas not commonly associated with seizing like exhaust studs etc. I see no reason why a fine thread bolt should be more prone to seizing, other than the fact that they are usually a better class of fit.
Fine thread bolts on a bike tend to be used where larger clamping forces and resistance to vibrating loose are required. Engine mounts (screwed into the alloy), caliper mounts, camshaft sprockets, tappets,spark plugs etc.
Carl_steveo
PostPosted: 10:08 - 09 May 2010    Post subject: Reply with quote
What the fuck are you lot on about.
Current: Honda Nsr 125
Live: Sunderland
The last post was made 16 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 110.55 Kb
