Bearing puller
Mr White
PostPosted: 11:12 - 09 May 2010    Post subject: Bearing puller Reply with quote
I need a bearing puller to pull my rear wheel bearing out.
Which one should I get?
Damon
PostPosted: 11:15 - 09 May 2010    Post subject: Reply with quote
A slide hammer bearing puller ideally, although you could probably tap it out from the other side as a last resort. I take it you mean a rear wheel bearing?
Mr White
PostPosted: 11:32 - 09 May 2010    Post subject: Reply with quote
Seen some for £80 Shocked Post a link if you can find anything cheaper.
Would this puller do the job?
https://m2.sourcingmap.com/smap/images/item/n/07c/ux_a07090700ux0034_ux_n.jpg
https://www.sourcingmap.com/threejaw-legs-gear-hub-bearing-puller-set-p-9950.html?currency=GBP
-on ebay for £7
PostPosted: 11:42 - 09 May 2010    Post subject: Reply with quote
Replaced wheel bearings loads of times and never used a bearing puller on them. It is a pretty easy job to do.
PostPosted: 12:14 - 09 May 2010    Post subject: Reply with quote
No you do not NEED a bearing puller.
No.
You would need a 'blind bearing puller' really.
However even then, it's easier to do it with a drift from the other side - when there's a bit of a gap, the blind bearing puller can make it a little less hassle, but I tend to still hit it from the other side, rather than use the slide hammer.
This is an example, I got a similar one (with more adapters) for £70 or so I think - second hand snap on blue line (or whatever it's called).
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170459497043
Mr White
PostPosted: 13:30 - 09 May 2010    Post subject: Reply with quote
I have tried to drift it from the other side.
But had no luck Neutral
The motorbike its doubt and has just done 11k miles, I doubt the bearing has been changed.
Sized?
PostPosted: 17:57 - 09 May 2010    Post subject: Reply with quote
Why can't you knock them out from the other side? You normally need to push the bearing spacer across to one side to get a lip to use to drift the bearings out
Quote Me Happy
PostPosted: 18:15 - 09 May 2010    Post subject: Reply with quote
Use a heat gun or a blow torch to heat the hub around the bearing so it comes out easier. Also use a good sturdy drift - I used a length of metal rod. Also check there isn't a circlip or something holding it it. Give it a good clean with some WD40 if there's muck around it.
PostPosted: 18:27 - 09 May 2010    Post subject: Reply with quote
Although it's amazing how much easier it is if you use a good sturdy drift as a drift on account of them being tool steel and therefore having a hard, flat face.
The last post was made 16 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 61.8 Kb
