snapped bleed nipple - XJ600N Diversion rear caliper
Swim41
PostPosted: 19:35 - 09 May 2010    Post subject: snapped bleed nipple - XJ600N Diversion rear caliper Reply with quote
Installed new pads today, and decided to change the rear fluid too. Big mistake. The bleed nipples have been snapped off flush.
Now, is there anything I can do without buying a new caliper? I notice that union bolts with integral nipples are available for this kind of application however, due to the design of the caliper with two seperate bleed nipples I am wondering if this will work.
https://www.dirtbikebitz.com/images/products/brake/Venhill_Banjo_Bolt_Bleed.jpg
Has anyone any experience of using these?
For reference this is two piston opposing caliper (one piston each side of the disc).
Forgive my ignorance. Smile
Yamaha XJ600N
PostPosted: 21:03 - 09 May 2010    Post subject: Reply with quote
You can use that with some messing around. If you pump the pistons out on the caliper with it removed from the disc it will partially-fill them with oil. Now lay the caliper on it's side with the oil line uppermost and squeeze the lower half piston back in. Because the air in the cylinder will be highest you'll force it into the upper cylinder. Now un-do the bleed nipple on the banjo nut and push the upper pisto in, the air will be forced back up the pipe and out of the nipple. A couple of repeats should get you a working brake.
Another option is to drill and tap a thread in the back of the caliper and use that as a bleed, capping it with a small screw and fiber washer.
Itchy
PostPosted: 21:56 - 09 May 2010    Post subject: Reply with quote
the simplest solution is a banjo bolt the kind that come with built in bleed nipples.
Swim41
PostPosted: 21:58 - 09 May 2010    Post subject: Reply with quote
Right, I'll look into it. At the moment the snapped nipples are tight so no worries about leaking. I'll try one of the banjos and see how I get on - expect a 'help!' post in the next week or so Wink
cheers
Yamaha XJ600N
PostPosted: 22:00 - 09 May 2010    Post subject: Reply with quote
Trouble with them is that the banjo is unlikely to connect to the highest points inside the caliper. Hence the need to do as Pete suggests and juggle around to get the air within the caliper up to the banjo.
Swim41
PostPosted: 22:08 - 09 May 2010    Post subject: Reply with quote
Bit of a quandry really. At the moment, I have a working brake. The fluid in there must be years old, but I can lock the wheel under braking. Front brake is good and recently overhauled. If I try fitting this banjo and it doesn't work out, it's new caliper time Confused as I haven't got the skills for drilling and tapping metal (sad fact, but true). Bit annoying though, as the bike is a 'keeper' and I like things to be in good order.
We will see.
Yamaha XJ600N
PostPosted: 22:17 - 09 May 2010    Post subject: Reply with quote
Personally I would suggest getting a spare caliper to give you a bit of time. Once you have that handy then take the existing caliper off and take it to a small engineering shop to drill the bleed nipples out
Itchy
PostPosted: 22:24 - 09 May 2010    Post subject: Reply with quote
If you have a spare caliper then why do you need the original drilled out?
Might as well just take the entire caliper off there and then and refill the system there and then too.
PostPosted: 22:32 - 09 May 2010    Post subject: Reply with quote
Only because drilling it out possibly leaves him without transport while it is being done.
Fair chance the replacement will not be far behind!
Robby
Dirty Old Man
PostPosted: 22:40 - 09 May 2010    Post subject: Reply with quote
Bleed nipples come in a few different thread sizes. Last time I had one chew its thread on the bike I drilled and tapped the bleed nipple hole up to the next size, to fit a car bleed nipple that was in my toolbox. I have also successfully used an screw extractor on snapped off one before.
Whatever you do, you'll need to completely strip and clean the caliper afterwards to remove every last trace of swarf.
M1ke
Ped Boi
PostPosted: 22:41 - 09 May 2010    Post subject: Reply with quote
I've had a few diversions now and they all have had snapped bleed nipples either on the front or rear caliper! I strongly suspect that they are made from cheese.
Before you buy a spare off ebay, obviously make sure that the nipple is intact, but also ask the seller to make sure that it can be undone. I bought a spare front caliper off Ebay once, the nipple was intact but once i'd fitted it to the bike, tried to bleed it, I snapped the f*cker. So was back to square one.
I've found the banjo bolts with the bleed nipples built in work pretty well and only cost a few £.
Walloper
PostPosted: 12:51 - 10 May 2010    Post subject: Reply with quote
Before you buy off ebay etc. you can still drill out the broken nipple and replace with a new one. Cheaper. Smile
robocog
PostPosted: 18:22 - 10 May 2010    Post subject: Reply with quote
Assuming caliper is alloy and nipple is steel (like they were on my CJ/CB360 monstrosity)
The way I did it when mine snapped flush was got a nut and welded it down the center to the end of the broken nipple
I'm sure the heat from the mig weld helped break the seal, and it almost span off using bare fingers once cooled
Worth a pop if you have someone handy with a mig welder?
I would be very cautious about using easy outs...can't think of any occasion where they have "just worked" for me
My (limited) experience is that they just break making the job 100% more inconvenient
Regards
Rob
Needs a bigger garage...
Swim41
PostPosted: 19:15 - 10 May 2010    Post subject: Reply with quote
Phoned up a local engineering firm and they think that it should be possible to drill it out and retap, but they'd have to look at it first. Alternatively, I checked at the local breakers and they have got second hand ones in stock, but whether they'd be willing to demonstrate the nipples being removed is another matter. Third option is to have a crack with the bleedable banjo and hope for the best.
Thankfully I've got a 125 I can use in the meanwhile until I get it sorted.
Thanks for the input, I'll let you know how I get on.
Yamaha XJ600N
The last post was made 16 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 86.27 Kb
