Disc stuck on my wheel !!!!! Help !!!
blownygti
PostPosted: 13:28 - 10 May 2010    Post subject: Disc stuck on my wheel !!!!! Help !!! Reply with quote
Tried to take my rear disc off the wheel last night managed to get two bolts off but can't budge the other two, anyone got an ideas as I need to take it off to have the wheel powdercoated tried hitting the allen key with a hammer as I was getting peed off, now the nuts have started to round off ! any ideas ? I have only had the bike 2 years but with it being a 1990 it must have been on there a while and seized on !!!!!!!
https://www.bikepics.com/members/blownygti/90cbr400/Default.asp
Itchy
PostPosted: 13:33 - 10 May 2010    Post subject: Reply with quote
Have you tried heating it with a blow torch?
As you've rounded the bolts off anyway, you can cut a slot into them and use a massive screw driver to undo them too with somebody leaing on the top of the screw driver and an adjustable wrench on the base of the screw driver.
Some plus gas may also help if heat does not.
Quote Me Happy
PostPosted: 13:37 - 10 May 2010    Post subject: Reply with quote
Use heat and/or some penetrating oil. Also try using an impact driver.
Mudskipper
PostPosted: 13:38 - 10 May 2010    Post subject: Reply with quote
I used copius amounts of Loctite Freeze & Release spray,
https://asaonlinesales.com/eimages_1/freeze_500_1.jpg
followed by the right size allen socket bit.
https://www.dfwsbr.com/crossfire/faq/porterfield/08AllenSocket.jpg
Normal L-shaped allen keys are useless for this kind of thing.
If that doesn't work, others may suggest using heat.
PostPosted: 13:42 - 10 May 2010    Post subject: Reply with quote
Impact driver is almost certainly needed. Most disk bolts are fitted with thread lock (normally already on new disk bolts), and heat will help to break this down.
The last post was made 16 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 44.99 Kb
