| dabigginger |
 dabigginger Crazy Courier
| Walloper |
 Walloper Super Spammer
 Posted: 22:15 - 10 May 2010 Post subject: |
It would do no harm to check them.
I don't know how it is done on that bike.
You will probably need a gasket or two and feeler gauges.
Valve Clearance will reduce as the engine wears. The seat and valve face wear off allowing the valve to sit further into the head. This causes the stem to move further up the guide towards the tappet/follower.
I would check them as a mater of preventative maintenance/peace of mind. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| YZFR1IAN |
 YZFR1IAN Scooby Slapper
| Raffles |
 Raffles World Chat Champion
| DrDonnyBrago |
| dabigginger |
| That_Hornet |
 That_Hornet World Chat Champion
 Posted: 22:11 - 12 May 2010 Post subject: |
Honda dealer near me doesn't do cb/cbr valve clearances until 30k unless it sounds like it needs doing. Their solid engines and don't usually need doing.
| YZFR1IAN |
 Posted: 22:23 - 12 May 2010 Post subject: |
What are the symptons of it needing doing ? ____________________ 05 Yamaha YBR125 > 94 Honda CB500 > 98 Honda Hornet 600 > 02 Yamaha R6 > 2000 Yamaha R1 > 2000 Yamaha XJR1300SP > 2000 Honda CBR929RR Fireblade
MY BIKES Past & Present |
| That_Hornet |
 Posted: 22:30 - 12 May 2010 Post subject: |
Tapping sound coming from the head, not to be confused with the sign of CCT wear.
Get a long screw driver and stick on the engine and put your ear to the other end. Listen.  |
| TUG |
 TUG World Chat Champion
| Noxious89123 |
 Posted: 23:08 - 12 May 2010 Post subject: |
What are the worries with loose clearances? Obviously tight ones mean you can start losing compression / power.
My bike has always been rather tappety, only really started AFTER I'd had the clearances done. Quite possible that they were tight before, and they adjusted them to the loose end of their tollerance. ____________________
| TUG |
 Posted: 23:18 - 12 May 2010 Post subject: |
Some mechanics like the sound of a loose tappet, some adjust them to be the inbetween tolerance (gives best results apparantly) some do them tight, if yours are loose, then i would imagine its been done within spec to allow for wear, if your not happy with this you should of taken if back when i was done, i doubt they will change it now.
I have to do mine soon, i've never done them before but i will hit the middle number, its not just a 4 min job, you have to correct the timing if its a cam out engine. Sadly mine is, gutted. ____________________ Haz ER-5, innit! |
| Noxious89123 |
 Posted: 23:35 - 12 May 2010 Post subject: |
The noise doesn't bother me, because I know what is causing it
No power loss or any other problems, CCT is good, so I don't see the point in worrying about it. ____________________
| TUG |
 Posted: 23:42 - 12 May 2010 Post subject: |
Thanks keith, now i have to worry about a burn out valve... maybe more of them lol.  ____________________ Haz ER-5, innit! |
| bacon |
 bacon World Chat Champion
| Walloper |
 Posted: 08:51 - 13 May 2010 Post subject: |
I don't see any point in putting a screwdriver to any bit of machinery to determine what is wrong with it.
Unless you know EXACTLY what you SHOULD be able to hear then you are wasting time.
That is like, 'Ocht don't bother going to A&E with those severe chest pains just get someone to put a screwdriver to your chest wall and they will be able to tell you if something is amiss.'
I suggest you merely 'CHECK' the tappet/valve clearances not necessarily 'ADJUST' which is an entirely different animal.
It is not a monumental task to check. Adjustment can be a pain if camshafts have to come out etc.
The exercise will benefit the inexperienced, be a learning curve for the enthusiast and as said no harm done. And it provides peace of mind too.
Some engines have a noisey background even in normal well maintained condition. This depends on the design.
Some are really smooth.
Tappet noise is a very specialist area and I would defy any mechanic to determine if tappets need adjusted just by ear alone.
(Unless they have knowledge specific to the particular application.)
That is why there is a very precise engineered value calculated for clearances.
We CHECK valve clearances not JUDGE them. I would sack a mechanic who told me, "Oh the tappets sounded OK."  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| bacon |
 Posted: 13:29 - 13 May 2010 Post subject: |
| Walloper wrote: | I don't see any point in putting a screwdriver to any bit of machinery to determine what is wrong with it.
We CHECK valve clearances not JUDGE them. I would sack a mechanic who told me, "Oh the tappets sounded OK."  |
if i can get away with doing something myself then id rather do it as opposed to a garage who wont take the same care as i do with my bike and charge me up the ass for it.
The clearances are specified for a reason, if they are out of spec and you are willing to do it then why not change them yourself. Your basically reccomending someone to not do something themselves and go to a garage, which for maybe most people thats a good idea, but if hes willing to do it himself dont discourage him.
if you dont know what your doing, your never going to learn by chucking it to a garage and emptying your wallet each time. Everything that my bike has needed doing to it has been all self taught and done by me, and id reccomend anyone who wants to learn to do the same
if however you have no interest in mechanics, maybe take Wallopers advice
edit: id also hazard a guess at the hornet engine using shim under bucket setup than tappets. if it is indeed tappets its even easier, did them on a wee cb250 and took no time at all. |
| TUG |
| DrDonnyBrago |
 Posted: 12:31 - 14 May 2010 Post subject: |
Ok so you would recommend going through all the hassle of dismantling the bike and checking the valve clearances, find one that was out of whack then reassemble and pay a mechanic to do it all over again?
I love working on my bike, I take better care and I learn a great deal whenever I do anything. The same cannot be said for taking it to some monkey with a spanner and emptying my pockets.
I also fundamentally disagree with your concept of not listening to your engine in order to determine if something is wrong with it. If you know what it sounded like before, and know what it sounds like after and where that sound is emanating from then even an amateur can have a fairly good idea of many problems with a bit of research.
Do you have shares in Honda by any chance? |
| Walloper |
 Posted: 13:28 - 14 May 2010 Post subject: |
| DonnyBrago wrote: | | Walloper wrote: | I don't see any point in putting a screwdriver to any bit of machinery to determine what is wrong with it.
Do you struggle with the 'written word' perchance?
No where have I recommended giving anyone money to do work one can do one's self.
If confident then by all means knock your self out with it. Though understand that confidence is no substitute for experience when you get into difficulties and your engine will not start.
And I maintain, nophuker, without extensive experience on the 'exact' equipment, can identify where the 'noise' is coming from by using a screw driver. That was an auld trick invented at Hollywood for WWI submarine movies to fool the Japs.
You are not a professional or tradesman is appears.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
The last post was made 16 years, 145 days ago. Instead of replying here, would creating a new thread be more useful? |
